Gear box oil
/ Gear box oil #1
Danica
Ulster County, NY
CNH TC40DA & Ford 1920
I just got off the phone with my CNH dealer regarding gearbox oil. The 930B 6’ finish mower I have says it takes NH 9821006 in the manual. On the other hand the NH 84 CSR snowblower says 80W-90. There is a huge viscosity difference between the two. The finish mower grease (NH 9821006) is almost as thick as Vaseline. There is nothing on the container indicating weight.
I hate to admit it but always assumed the gear boxes on my rotary cutter, finish mower, and snowblower took the same gear box oil. After all, they’re all taking in 540 rpm but I realize the internal gear configuration results in a pretty slow output speed for the snowblower while the finish mower must have very different gears to generate the blade speed necessary for it to work properly.
Have I erroneously assumed all implements gearboxes take roughly the same viscosity oil? Please help as this will occupy the res oft my day (checking equipment etc).
Thank you so much in advance anyone who can shed light on this mysterious situation!
Danica
/ Gear box oil #2
The textbook answer is that it's a safe bet to go with the manufacturer's specified lube. That said, I use 75w140 in every gear box I own regardless of what the OEM specifies. I have never had a gear box failure on several high hour machines.
/ Gear box oil
Thanks I will print this and post it in my barn!
2023 John Deere Z950R Zero Turn (A63116)
2023 John Deere...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2022 Kubota 74in. Hydraulic Dual Cylinder Grapple Skid Steer Attachment (A61567)
2022 Kubota 74in...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2018 New Holland C227 Compact Track Loader (A63118)
2018 New Holland...
2014 Chevrolet Silverado 1500 (A64047)
2014 Chevrolet...
