/ Your last generator Maintenance Run #6,841
Some sensitive electronics like UPS systems “sometimes” have issues with the dirtier sine wave that 2 pole generators put out. That being said, ive run my house off of 2 pole generators since 1996….heck, i built my house off of a generator, and ive never had any issues.
My generac whole house is a 2 pole unit, so technically its somewhat dirty power. But while on the generator, all my electronics including 4 UPS systems have never had any issues.
My 22kw generac only cost $4500 back when new…..well, mine was free (but thats another story). I like inverter units made by Honda, but they just want too much for them. I was looking at one for use around property (like the quiet aspect), but bought a briggs 6.5KW for about $500 as opposed to the nearly $4000 honda wanted. Ill live with the noise. And it runs my skill saw and drill and wire feed welder just fine.
/ Your last generator Maintenance Run #6,842
yeah, you want a pure sine wave inverter, not a modified sine wave.
A lot of UPS put out a modified sine wave, that's junk!
/ Your last generator Maintenance Run #6,843
My new UPS doesn’t like running on generator power. I think it happens when the well pump kicks on. The UPS just shuts down.
/ Your last generator Maintenance Run #6,844
A nice used 25-40HP tractor to run the PTO generator and your all set.
Log into Facebook
Why do you say " It's also an inverter generator which, unlike the PTO genny, is safe for electronics."
I have had absolutely no issue with electrics on my pto generator nor has the farm and we have been using them from the 60's.
Depending on the quality of the inverter they can and have had issues with electronics as they are a modified sine wave and depending upon how many steps they make to make the full modified sine wave is important.
They are generally not modified sine wave. I haven't seen a modified inverter generator sine wave, most have THD below 3%
/ Your last generator Maintenance Run #6,845
UPS's have issues with the frequency drift, not a dirty sine wave, they generally want around .5 hertz deviation, i have not seen a mechanical generator with a non electric governor hold better then 1 to 2 hertz
/ Your last generator Maintenance Run #6,846
Modified is what my 1990 inverter is and it runs all my power tools and light boom but it will not run a Mikita or Dewalt cordless tool battery charger.
/ Your last generator Maintenance Run #6,847
ive been told there is a way to adjust UPS devices to use with a generator, but i didnt need to do that with mine. my generator holds 60HZ very well.
/ Your last generator Maintenance Run #6,848
higher end UPS have settings deal with this, most consumer cheap units, do not (they have a sensitivity thing, but that is generally related to voltage not frequency (I have 13 ups's in my house, and have gotten burned by this, until I went inverter generator)
/ Your last generator Maintenance Run #6,849
Exactly. "Pure sine wave" is pure marketing bullsh*t. There is no such thing, other than in theory. Check the THD spec, that's the proper metric.
/ Your last generator Maintenance Run #6,850
I've run my pto generator on at least a half dozen different tractors non of them had an electric/electronic governor and all of them have held the hz to under 1 hz except when I tried to use the IH574 on the 1000 rpm shaft at half throttle then it was not stable enough.
I know that many inverter generators and power supplies advertise pure sine wave power. I have not stayed on top of the latest and greatest power systems but I know of no way to get pure sine wave except from a rotating field any "solid state" device is going to be a modified sine wave it may have enough steps and buffering to be almost indistinguishable from a true sine wave but it is still a modified sine wave.
/ Your last generator Maintenance Run #6,851
true, I've not come across an actual standard, just marketing....
  • "Clean Power" or a "Pure Sine Wave" is considered to be power with a THD or less than 6%
And like you said, the real goal is <3% THD
My previous generator THD spec was 25% the new one is <3%
Interesting read here: Generac Help Center
/ Your last generator Maintenance Run #6,852
any of us who come from a hi-fi background know those distortion levels are huge for
sound amplification. My APC UPS so far has not weirded out while the gen runs.
I would have thought "clean" power would be less than 1% THD.
not like THD is going to hurt a toaster. Most appliances used to be durable but now equipped with blue tooth
and other digital displays, some in color, I wonder if complexity has made them less durable.
/ Your last generator Maintenance Run #6,853
Northern CA may again have the opportunity for generator power as a possibility for power safety shutoff even announced due to high temps combined with wind.
/ Your last generator Maintenance Run #6,854
I come from industrial electronics design background, so my knee-jerk reaction to this is, “no”. These features work off DC, provided by simple and cheap voltage regulators, and easily cleaned up with a few capacitors. It’s terrible design, in my world, to leave a circuit vulnerable to this.
But then I have to remember consumer electronics is all about shaving pennies, or even fractions of pennies, and capacitors cost money in both direct cost and PCB real estate. Heck, even the days of extra R&D work to characterize and test the circuit against such power anomalies could be a factor. So, compromises will be made, not by accident.
/ Your last generator Maintenance Run #6,855
I hear you from a circuit standpoint, but so many electrical surges now, either home generated by a/c compressors or spikes in line.
power here often goes off and back on in seconds. I would love to have an oscilloscope and THD analyzer on the line when that happens.
Get hit by lightning and most electronics are poorly protected.
my nephew has a microwave oven with a push button motorized drawer. With a color screen. And wifi.
born to break.
I remember the first Amana Radarange that came into our area, friend of my parents had one.
Looked like the front end of a 56 Buick. Massive heavy chrome thing.
we've come a long way.
Of course like many of you I know what a hand wringer on a washing tub is.
Ask a Gen Z how to operate that and I bet they think it makes pizza.
But given any kind of care at all, it's still working.
it's remarkable how many advances we have made in both output and reducing size.
And for sure cost.
WinterDeere, I used to own my little town's Radio Shack. I've seen a lot of broken retail electronics.
that's where I learned
if you teach it to drink it will soon learn to smoke
industrial: how can I make it better and more MTBF
retail: how can I make it attractive yet cheap as possible to sell at a certain price point
I have seen some great electronic designs. I sold hundreds of Sony Trinitrons and only got one back, the one with the built in VCR that
someone had jammed a tape in. But those Sony tubes, bless their heavy weight, were super reliable.
I just wonder if my OLED Samsung will last as long.
Now I do admit to giving every Sony tv customer a free single outlet surge protector as part of the sale.
Always wondered if that was a big factor in reliability.
from memory, only other expensive electronics I sold that never came back for repair were the early Motorola and Panasonic
bag phones. Contractor phones for the front seat of the boss's truck. Then later early adopters for cars.
Those phones were likely built almost to milspec, they were heavy, tough and rarely broke.
They just became dinosaurs technologically and could not be upgraded further.
And there was always the customer who wanted the first Motorola hand held cell phone
/ Your last generator Maintenance Run #6,857
born to break.
lol... you just reminded me of some advice I got from my very first boss. I was an EE intern, and he had dual BSEE / BSME degrees. His words were, "when a system fails, always look for the electromechanical component." Essentially, the fail rate on electronic circuits is 100x lower than the electromechanical components. Think back to your monster stereo component towers... it was always the tape decks that failed before the radio tuner! Always the speakers that failed before the amplifier, etc.
Yep... I think that sums it up! Once a technology becomes stable, then the sheer number of units sold make it easy to improve reliability, at very low per-unit cost. New consumer tech always pays the price, trying to straddle that cost vs. R&D investment line. Dealing with anomalous events, such as mains power spikes, becomes a game of reputational / marketing cost impact for failures vs. actual manufacturing cost.
Thanks. This is one for the "you know you're old when..." thread, as it falls under the "stop telling yourself you're still 25 years old," category of injuries. Hard wipe-out while tubing behind a boat, probably going a little too fast for my age.
Now I have to listen to my wife remind me I'm an idiot, for the next few weeks. :D
Reminds me of a recent Leno video (JLG driving the new Morgan 3 wheeler).... he made a comment about crashing motorcycles. "I figured I had one more more good-crash in me, then I crashed my Indian (within the year +/-). Now that I'm healed up again, I figure I still have one more good crash in me....."
A shout-out to the better-halfs we have - they know we are idiots, but still choose to hang-out with us ! :cool:
Rgds, D.
Yes, they do have a fan only setting.
Can I bother you again, for the brand-name and model if they have one ?
Couldn't make out a name in your pic, and that 411 ^ could save me a lot of time on Amazon !
Thnx, Rgds, D.
A used tractor is a possibility as long as it isn't someone else's problem. Finding a decent one for $5K would be a challenge. There is also the storage issue. It would have to live outside.
It depends on the generator and the electronics as to whether it can do harm. I'm involved with A.R.E.S. and am usually on the air during outages. I lost a $2K digital ham radio to the PTO genny I have, so I guess mine isn't good quality. I've never had an issue with Honda inverters.
I was reading your longer post above, and batteries were drifting through my mind.
Then I read this one ^, condolences on losing the radio. That may have been a line-only base, but what I settled on for mine (ARES too) was a group 31 AGM. Nowadays, LiFe is coming down in price, so even more options exist, beyond traditional FLA.
It takes space/money/time.... but one of my favourite self-built hybrid setups on here is what 90cummins runs, and continues to evolve. Like modern iGens that Coastie just snagged, the key is the design and quality of the Inverter. The industrial one 90 has (I want to say Schneider (?)), even has a support function to assist a smaller-gen start a heavier load.
Someone recently posted that re-purposed Municipal surplus generator they installed to support a commercial machine shop - there ^, you don't have much choice, but most of us, most of the time, have just relatively light loads to support @ home - when in Survival Mode.....
Rgds, D.
2001 Peterbilt (A60352)
2001 Peterbilt...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
KBH Tank Trailer (A61307)
KBH Tank Trailer...
2018 CHEVROLET EXPRESS 3500 4X2 BOX TRUCK (A59906)
2018 CHEVROLET...
