NX 4510 loader drifts down
/ NX 4510 loader drifts down #1
Theo 69
Kioti NX4510
I have a NX 4510 and as soon as I release the back pressure on stick the loader falls. To trouble shoot, I have switched hoses from the bucket curl cylinders to the raise arms cylinders and had no down drift. So I have concluded that the valve spool body is leaking internally. I have no oil leaks externally. Went to dealer and the only part they offer is a total valve spool body replacement at $1500. Looking for any advice on a fix without a total replacement.
/ NX 4510 loader drifts down #2
Sounds like the spool is not returning to center properly. I would suggest checking all the linkage or cable between the joystick and spool to see if anything has come loose. Then measure the exposed portion of lift lower spool vs curl dump.
There is nothing in the valve that you can repair since it is metal to metal seal of spool to valve bore.
/ NX 4510 loader drifts down #3
Very sound advice oldanslo. Something good happens anytime you do what you can
F-150 4WD (A63689)
F-150 4WD (A63689)
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
