F535D parts
/ F535D parts #1
nickwi
1959 Allis Chalmers D14
I have the chance to buy an F535D had a very good price. It's low hours and has a nice loader on it. The current owner describes it as having power to the front drive shaft into the front lift wheel but not to the right. I'm guessing a gear or something sheared off.
I've done quite a bit of googleing but not found much luck locating parts for that tractor.
Can anyone help with that? I've worked on several older YM tractors and owned an f-32. I've not owned any of the F _ _ _ (3 digit) tractors yet.
Thanks in advance! Nick
/ F535D parts #2
I'm thinking you have a rare one there. I guess you are confident the differential is not causing only the left wheel to turn and if so are you confident the left wheel is turning with power? Sounds strange to me. Have you done careful checking with front end jacked up, turning one tire and seeing what happens to the other, in and out of 4 wheel drive?
/ F535D parts #3
There are free manuals on the YTOG,
YANMAR F395 F475 F535 F605 OPERATIONS MANUAL ON03-00864.pdf
YANMAR 3TN100 4TN100 PARTS MANUAL 0CD10-G45800.pdf
Closest engine SM are,
YANMAR JOHN DEERE ENGINE 3TN 4TN SERVICE MANUAL CTM3.pdf
YANMAR TN TNA SERVICE MANUAL 3TN-890216.pdf
/ F535D parts
Hi bmaverick, were those supposed to be live links to the PDFs? I tried to open them, can't figure it out. Looks like it takes me to a site where I have to pay to open the PDF. Thank you for responding!
Winston1 I have not yet put hands on the tractor. It's quite a distance from me and right now I'm going on the info from the current owner. He said 2wd works fine, 4wd makes some noise and sends power to one front side but not the other. I did find a whole front end down south just in case. Apparently an F435 and F535 use the same front end parts. Owner is gone for vacation, I'm going to check her out when he gets back. Thanks for your response!
/ F535D parts #5
I have a complete F435 fwd axle. it some of the same gears & housing of the F535
/ F535D parts #6
The way the differential works on the 4 wheel drive only the wheel with the least resistance will turn. Noise is another issue. Sounds like some trouble shooting needs to be done.
/ F535D parts #7
Nope, the link is in my SIGNATURE to get to the YTOG. Joining is free, the manuals are free. We are the largest community Yanmar Tractors Owners Group on the web.
I only posted the pdf's as what the site has.
/ F535D parts
Got it, thank you, just joined!
/ F535D parts
Thank you Len! Getting a little gun shy about this tractor. I haven't yet laid eyes on it. The owner is away for a month on vacation. The more we chat about it the more concerned I am about it's rarity! Could be a great 50 horse tractor for $8,000. However I do plan to use it and sometimes that takes parts. I guess I will know more when I see it unless I find something else before then. I really appreciate all the great information this forum provides!
