John Deere 5205 Top Link Repair
/ John Deere 5205 Top Link Repair
I tried unscrewing the ends of the top link that came with my 5205 when I bought it new in 2006 and the ends unscrewed easily. I think your link took a heck of a bang at some point and ruined some of the threads. Are those rubber plugs perhaps filling in threaded holes for grease fittings?
Thank you for sharing this pic. My unit is a 2004, but can't imagine much change in the top links. I am not sure if the plugged holes are threaded. Will have to get better lighting and check closer. I also have access to a much larger and more secure vise. May have time this weekend to see if can get it locked down and get better leverage on it and see if can turn it on out. Knowing there was nothing in yours that had to be removed or driven out to get the link ends to come all the way out is very good information!
/ John Deere 5205 Top Link Repair #12
You said in the OP
found one end turning, but not going in or out.
That indicates that the threads are stripped.
Different if one end is stuck and not turning.
Hope you let us know if locking it down tight will get the end to turn out.
/ John Deere 5205 Top Link Repair #13
Go buy a new one at any farm related store. TSC sells them everyday. Not expensive so toss your old one and buy a new one. Much easier. JD dealer will ream you btw.
You said in the OP
After closer inspection last night I was able to determine that it does appear to be going "in", but not far. After removing the plugs I could look through the holes and tell it would go back in enough to block them. Movement may be 1/2" to 3/4".
I don't care to spend several hundred dollars on it, but if is just a matter of a little extra help I would like to get it back working.
I do have a replacement in use now, but would like to get this one back going if nothing major. When I looked at the individual component prices on JD Parts I about fell out!
/ John Deere 5205 Top Link Repair #16
Get yourself a rear remote and replace it with a hydraulic top link. Like A/C once you get used to that you will never be without it.
Was able to dig into this a little more this evening. Bigger vise, little penetrating oil and cheater pipe allowed for backing both ends all the way out. Turns out there was a roll pin in each end, but was able to back all the way out anyway. With more penetrating oil was able to thread both all the way in which required more cheater pipe at times. End result is back in service. I believe continued use and lubricant will help it get even better in time. I can remember the top link seeming to be froze up 15+ years ago when I borrowed this tractor from original owner. Guessing it just needed some elbow grease and using.
Here are pics along the way.
/ John Deere 5205 Top Link Repair #19
So there was a change in top links between 2004 and 2006 - mine certainly has no roll pins. Although on mine there are bosses on the main casting where there are holes in yours, mine isn't drilled through to allow installation of the pins. I like your attitude of repairing something if possible rather than just scrapping it as others have suggested. Thanks for posting the update.
/ John Deere 5205 Top Link Repair #20
Being hard to turn could be from it getting bent and straightened back.
I was boxblading once and pushing hard, had the cheap top link bend some. I did have it run out to dozer the blade.
After straightening it never worked smooth. Sold with tractor.
2005 John Deere 7320 (A60462)
2005 John Deere...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61307)
Midwestern...
(250) Iranch Safety Traffic Cones (A60463)
(250) Iranch...
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
24220 (A56859)
24220 (A56859)
