The lets build a cage for our kubota B2601...
/ The lets build a cage for our kubota B2601... #1
Bansil
Gold Member
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
So next project is going to be some protection from falling limbs, branches and to help protect me when I flop her. (Not if.... I have rolled and flopped too many vehicles to not do it eventually) 🤪 This may be slow, but this thread will keep me motivated to get it done in a few weeks hopefully.
Stay tuned....
Plan is 100% bolt on, cut a mount for fit and function or proof of concept.
Woop! It fit.....multiply...multiply...
Sorry no fit pictures...
Just cut these an hour ago or so...
YUP...They fit....
/ The lets build a cage for our kubota B2601... #5
subscribed. Great project. Smart project. Looking forward to seeing what you come up with.
/ The lets build a cage for our kubota B2601... #6
Getter done! Thanks for taking us along with you.
/ The lets build a cage for our kubota B2601... #7
Working in woods, trees on our hillside farm a four post ROPS is a necessity. One of many reasons I like the Kubota TLBs. Their FELs are not removable.
Added front posts and steel top to 80s model B20 forty years ago. That’s the tricker part of your build. Design to still remove the FEL with four post ROPS?Some steel tubing and golf cart top should be an easy build.
Mounting for the front posts?
Small brackets are for the ROPS connection or
("B" bar). The bigger ones are for the ("A" bar)
These are 3/16 thick. Got the day off so we are going hiking with the dogs, will do more tomorrow or maybe tonight.
Plan to incorporate a lot of things, tool box, saw mount, shovel, chains etc.
Yes, all removable as per factory design. I am at 2 holes to drill so far 1 each side of FEL.
/ The lets build a cage for our kubota B2601... #10
Adding chainsaw, fire extinguisher, chain, long tools mounts makes the tractor safer and a pleasure to use. Four post allows many options for improving lighting and mirrors.
/ The lets build a cage for our kubota B2601... #11
Maybe incorporate a grab handle on the front upright for safer egress in and out of the tractor?
/ The lets build a cage for our kubota B2601... #12
All the Kubota TLBs use what looks to be the same design for the 4 post ROPS - just the size is different.
When we got the M59, it was our first tractor ever with a 4 post canopy, and I like it.
Making a 4 post ROPS into a cab could be done, too.
Definitely going to make it comfy, have built enough cages to know that at 25 years old is different than 55years old bodies don't move the same 😛 I got to go to the dump 1st today, then find the old fab shop....old wood building 😉
Plan several hand holds, I have some 1/2 tubing to bend for them.
/ The lets build a cage for our kubota B2601... #15
I have been really wanting to do this on my m7060 as well! The way the canopy mounts leaves a lot to be desired. I keep raising the canopy so that I can stand on the tractor and it keeps falling back down. I have been thinking of mounting in the same location, I will be watching your progress.
/ The lets build a cage for our kubota B2601... #16
I did the same but with a full skid pan. I'll try to get a link to my post here, it was about 8 years ago.
/ The lets build a cage for our kubota B2601... #19
It looks like a great project.
I'm pretty sure I'll eventually end up with a cage around my Landini trekker crawler. The ROPS just isn't enough.
Are you bolting to your front end loader? It should be a sturdy place to connect to, but if you ever have to remove the loader, the cage will also come off.
Hope to work on it today after a few honey do things. I do not plan on taking the FEL off ever unless it gets damaged some how, but worst case would be take a bunch of bolts loose.
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
