Push/pull switch wiring help
/ Push/pull switch wiring help #1
Stepadery
DR Field and Brush Mower PRO MAX52T
I have a 2021 DR Field and Brush Mower Pro Max52T. I pulled the wires off of the push/pull TPDT switch. The wire colors are red, orange and 2 whites. The switch itself has 8 pins, 2 rolls of 3 and 1 roll of 2. I need assistance on what wires go to which pins on the switch.
Thanks
/ Push/pull switch wiring help #2
Is the switch lighted? The diagram should typicaly be on the switch but what the wires need to do should be in a diagram that DR has.
Typicaly the power and ground would be the center terminals and the outer ones would be the switched terminals. I believe the switch is lighted so theres an extra pair of terminals for that.
A representative (Brian) from DR assisted me with this. He was a great communicator and stuck with me on this until it was resolved. Thanks all for your suggestions.
/ Push/pull switch wiring help #4
So, what was the solution?
/ Push/pull switch wiring help #6
Thanks for the update.
