GC1725 FEL (FL1805) Pin Rattles Out?
   / GC1725 FEL (FL1805) Pin Rattles Out? #1
hube2
Paris, NY
Masey Ferguson GC1725M
FL1805 has anyone had issues with the loader pin rattling out? In case there is a question about what pin I mean it is item 5 on the image.
I've had this happen a few times, luckily I've always been able to find it.
   / GC1725 FEL (FL1805) Pin Rattles Out? #2
Use a zip tie to tie the ring to the pin. Or a piece of wire or something. That will keep it from getting pulled out.
   / GC1725 FEL (FL1805) Pin Rattles Out? #3
You can always replace it with the same size PTO pin. They come various sizes and lock more securely than a lynch pin. The also do make some better lynch pins.
I seriously don't understand how it's coming out. It's always closed when I find it and is seems tight and secure when it's in place and takes some effort to make it pop of without opening it. I also know that this time nothing, including myself, got in between the loader frame and the tractor that could have pulled it off.
   / GC1725 FEL (FL1805) Pin Rattles Out? #6
That pin is pulled to remove the loader it should not be tight unless in tension while FEL is used. Seriously a 2 buck PTO pin will not wiggle out as easy.
Pin has lost its tension...Replace it.... OR as others state, wire it or ZIP tie....
Yep, I'm ordering some, smaller than the 3PT pins, only 5/16. I think the tension on the pin has always been bad, first time it happened I'd only had the tractor a couple of months. Should have gotten new ones the first time it happened, but I was being lazy.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56438)
Adams Load Out...
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
