New Kubota Corrosion
/ New Kubota Corrosion #61
Check your electrical connections. Maybe a bad connection is causing galvanic corrosion?
Finally, someone that knows what they are talking about. I was hoping that this post would go on forever before that knowledge was revealed. Love having the answer and seeing all the pot shots and arguments when know body actually knows. Very few people know of this problem, but I've delt with this a few times even on some aluminum boats as well. Bad connections and a bad battery will cause this to happen.
Dave5 and stripeblue12 Get a new battery, check and clean all your connections.​
/ New Kubota Corrosion #62
We're on our 3rd Kubota tractor, the first being a 20 y/o sub compact 2230 that spent the first ten years in NY where we use salt on everything. The little guy was garage parked there and barn parked here and has been used for everything from snow plowing to manure management. We have no corrosion on any fittings or elsewhere for that matter. Our M70/60 is 5 y/o with 1100 hrs, always barn parked and used for all sorts of farm activities. Again, no corrosion. The made in China parts concern me. I'm not clear when Kubota started to use Chinese manufactured junk on their machines but that could be the problem. I read the other responses herein but your tractor is barely broken in and unless you are washing it in salt water I see no reason for this level of corrosion. What does your dealer say?
/ New Kubota Corrosion #63
Very True, However the change From yellow Zinc Cadmium Plating to more ecology safe coatings is a minus in corrosion protection.
/ New Kubota Corrosion #64
Perhaps but this machine is almost new with less than 100 hrs. Troubling
/ New Kubota Corrosion #65
I am also curious about using ACF-50 for general use. Although they state that it isn’t harmful on rubber surfaces, I’m a bit concerned about overspray on rubber hydraulic lines and/or seepage/infiltration into gaskets/o-rings.
Anyone have experience with this product in regards to my unfamiliarity?
/ New Kubota Corrosion #66
I would wash throughly with purple simple green to remove any salt. CorrosionX is my spray lube and protector of choice.
Using CorrosionX on PTO couplers, splines and shafts make connecting so much easier than using grease.
/ New Kubota Corrosion #67
I'll be keeping a close eye on my Kubota 4160 baler that was delivered a few weeks ago. Also barn parked but it was outdoors at the dealer.
/ New Kubota Corrosion #68
Hello All, I have been reading a learning a ton on this site. Thank you to all who contribute.
I have a 1 year old Kubota 4760, 2022 model delivered in May of 2023. I am appauled by the corrosion on all the silver plated hardware. The tractor has 55 hours on it, and is kept either in my garage or under a 3-sided barn, it does not see the rain/snow. It stays on my property and gets washed a few times a year. I live in southern New Hampshire, not by the beach. It appears that just condensation has corroded every single plated fitting/hardware item. I have a BH92 on this as well, and all the silver connectors, even hose clamps, are corroded. Am I just expecting too much?
Some of the fittings say China right on them. I'm dissapointed and will now go and try to steelwool/oil all the parts, but what a waste of time. Here are pictures of the hydro connections for the FEL, under the cab and for 3rd funtion valve. I took these pictures a few weeks ago, on a warm morning. You can see some droplets from the humid air on the cold metal. Notice on the middle picture on the cab, some connections have zero corrosion, but most have the oxidation. I really expected more for the money spent on this. Any thoughts or insite? Thanks!
It looks like hard water corrosion, I live in southern New Mexico, a desert, our water is "hard" and fittings look like yours after several washings.
/ New Kubota Corrosion #69
Good chance it sat, disassembled, on the deck of the ship that brought it in. Or it could just be that Kubota buys their hardware from some less than stellar supplier in Chinal.
/ New Kubota Corrosion #70
Yo Dave
I be got a 5 yr old mx5200 with 800hrs
Its in central Ky, mostly in the barn but it’s spent some time in the rain as well
I also have (2) ZD1211….. 60” and 72” decks
I have nothing on any of my fittings that resemble that
The only thing Ive seen cause a reaction like that is when some tools , saw blades , tool boxes etc were left in our pool pump filter room where there was also chlorine tablets stored…I’m assuming that’s called “oxidation”
Any chlorine nearby?
Yeah with 55 hrs I would think kubota would do something for you
That is, if you eliminate anything you might have accidentally exposed it to. Also like someone else mentioned,
whenever I think about it , I wipe down all my fittings with a little wd40…or spread a little extra grease on them
At 55 hrs though I don’t see that being anything that could have prevented your problem .
Bad Chinese run of fittings?
Chlorine nearby ?
Good luck man
/ New Kubota Corrosion #71
Sounds to me like you live close enough to the ocean where the prevailing winds are carrying the salt spray to you... Personally speaking (opinion only). I don't see Kubota giving you any sort of compensation, but then I've been wrong before.
/ New Kubota Corrosion #72
There may be an electrical issue. Possibly a chafed wire touching metal somewhere. Aluminum will corrode when there is electrical current passing through it.
/ New Kubota Corrosion #73
Are you thinking those fittings are aluminum? They look like poorly zinc-plated steel to me. But a magnet would tell for sure.
I'm guessing the corroded surface hose fittings came with some sort of aftermarket or accessory fitting instead of being Kubota tractor parts, because we've seen before that Kubota doesn't pay strict attention to the quality of their accessory manufacturers. But only subcontract manufacturers, not on the tractors themselves.
The fittings in the OP photos seem to be a different color plating from similar types of OEM fittings on our old Kubota backhoe and loader.
/ New Kubota Corrosion #74
There was that one time in ought 8 or was it ought 9?
/ New Kubota Corrosion #76
Doesn't matter much the metal. For example, you see that corrosion on both ends of a battery cable (copper) from the battery to the starter or solenoid. With the power off it leaks a weak backwards current to ground. Ground would be any part of the tractor that would carry a current including fluids. The plating on the bolts also shows it. The battery will usually test good or indicate it needs recharged. I've seen this quite a few times on aluminum boats. With the boat being wet you can actually see it foaming out of rivets.
/ New Kubota Corrosion #77
DEFINITELY!!! That is not normal. Something is going wrong there. I would ask Kubota to come have a look and ask for their appraisal of this condition.
My Kubota M6040 fittings and all piping looks the same as the day I bought it - brand new.
I have a 20 yo BX and the fittings still look like new. I would definitely lodge a complaint… those fittings are going to give you trouble. Obviously Kubota has cheapened their sources. Disappointed in them.
/ New Kubota Corrosion #78
This thread is becoming pretty ridiculous.
I’d make them give me a new tractor, a spare set of hoses and a full refund! lol.
/ New Kubota Corrosion #79
A very bad idea. Have you ever seen a classic car that a person threw a tarp over it to "preserve" it, only to find the interior filled with mold?
If one wants to prevent condensation from forming, one needs air movement. A ceiling fan set on low does wonders and costs pennies to run.
I store my classic cars in zipped up plastic bags with plenty of desiccants inside the cars as well as in the bag.
/ New Kubota Corrosion #80
I believe you have several contributing factors. First is that condensation regularly soaks the components due to your climate and storage location. Even so, corrosion on a one year old tractor is inexcusable. Next is inadequate plating. Remember that zinc plating is intended as a sacrificial anode that needs to corrode to prevent steel parts from corroding, so a thin layer of Zn turns into zinc oxide (the whitish powder) quickly in the presence of water, especially salt water, which is more conductive. Trouble is, you can't tell thin from thick plating when everything is shiny new, so Kubota's plating specs are obviously insufficient or not followed by suppliers. Also note that steel with yellow zinc plating has an additional top layer of chromate that improves corrosion resistance. Steel wool will do nothing but remove the already-corroded zinc. Oil may help short term, but I suggest cleaning then spraying with a lanolin-based aerosol like Woolwax or WD-40 LANOLIN. Another issue may be that your tractor sat on the dealer lot exposed to the elements over a long period as many do. Does your nameplate show date of manufacture? I bought my L39 used and am unfamiliar with Kubota's warranty, but it seems to me that your degree of corrosion after only one year should be covered.
Hustler Super 104 104in. Zero Turn Commercial Mower (A61567)
Hustler Super 104...
2026 Hillcrest Trailer 14166SPT 7 Ton T/A Partial Tilt Trailer (A61569)
2026 Hillcrest...
2021 John Deere 320R Loader (A63116)
2021 John Deere...
INOP/NON-RUNNING 2004 Freightliner M2 106 Medium Duty Day Cab Truck, VIN # 1FUBCXDC24HM93001 (A61165)
INOP/NON-RUNNING...
2024 John Deere 8R 410 Tractor (A63109)
2024 John Deere 8R...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
