Dump Trailer - Rock Question
/ Dump Trailer - Rock Question #1
ODZD
Member
Ck2610
Noobie here, literally have maybe 1-2 hours on our new to us tractor. We've had a dump trailer for hauling stone, firewood, mulch, etc. but we need to replenish some of our landscaping stone around the house. We have black granite, so it's a bit bigger than your normal 3/4" rock. What's my best bet here to get it out of the dump trailer and use the tractor to move it?
1. Dump it on the driveway and scoop it up
2. Try to use the dump trailer to dump it into the bucket (Figured less mess - maybe more work?)
3. Please don't laugh, I'm a reformed yuppie.
I just was trying to avoid dumping it into the grass or driveway to reduce clean up/spillage
/ Dump Trailer - Rock Question #2
Dump it wherever you need it on a blue tarp. It's not perfect but you can get most of it up.
/ Dump Trailer - Rock Question #3
Using a blue tarp is a good idea.
Or, could you tilt the dump trailer slightly, then shovel it from the dump trailer into your loader bucket?
/ Dump Trailer - Rock Question #4
Depending on dump angle, bucket width, and trailer width; dumping directly into the bucket is the way to go to eliminate waste/mess. Most dump trailers, the back is so low when dumping, it's hard to get the tractor bucket under it, while curled to keep from spilling.
/ Dump Trailer - Rock Question #5
I tried the dump into the bucket method, it worked, but there was still a little mess, and it was kind of a pain back and forth with the dump making sure I didn't damage something when the rock backed up in the bucket. Could easily bend the bars that the ramps attach to.
/ Dump Trailer - Rock Question #6
I use my neighbors dump trailer to get a few loads of rock and his will let you chain the tailgate so when you dump it only opens a few inches so you can limit how far it opens. The only thing is the trailer is wider than my bucket, but I don’t get a whole lot on the ground And I have said 5 gallon buckets where my buckets getting it and let it dump into the 5 gallon buckets also
/ Dump Trailer - Rock Question #7
I've done similar with mine. (Steel bed) With the right tilt, you can pull it in fairly easily with a rake, or push it in from the bed with a rake.
Extra points for putting down a tarp where some inevitable spillage happens.
/ Dump Trailer - Rock Question #8
A buddy of mine, when he had his dump trailer, backed it up on ramps to allow more height to dump from. He also had a wireless remote wired up so he could be on tractor and control the trailer! Was pretty slick setup. Feel free to copy!
/ Dump Trailer - Rock Question #9
I like to use sheets of plywood.
Ahh that was my thought process, maybe I just bite the bullet and dump it on a portion of the driveway with a tarp.
/ Dump Trailer - Rock Question #11
Another good idea is to split a piece of pipe and fit over the cutting edge of the bucket. That way, it'll slide on the driveway and allow the stone to roll over into the bucket. I did this for a neighbor with a paved driveway. Didn't scape up the driveway with the bucket.
/ Dump Trailer - Rock Question #12
How wide is your trailer. My one-ton is 7' wide and my buckets 5' and 6' wide. I load the buck in the truck. When the pile gets to far forward to reach I close the tailgate and raise the bed go get the material back to the rear then go at it with the bucket some more. This is my 5'er on the L3010.
gg
/ Dump Trailer - Rock Question #13
I did this with mine for both wood chips and small crushed stone and to my surprise it worked and was easier than I thought. It's my go to method for situations like this.
Dumping on a tarp is awkward and you never get it all up because the tarp is in the way and doesn't lay flat. Dumping into your tractor bucket can be messy if the trailer is wider than the bucket.
/ Dump Trailer - Rock Question #14
I've never used a dump trailer, but I do own a small dump truck, and I have gravel and top soil delivered to my place almost every year. Where to have it dumped is always something that I put a lot of thought into.
For topsoil, I've been having them dump it where I keep my round bales, and not an area that I consider nice grass. One day I hope to make it all gravel there, so I'm not too concerned what happens to the grass that gets covered by 8 yards of top soil.
For gravel, I have them dump on my driveway, where it's not in the way of our cars. My thinking is that what I don't pick up, will just add to what's already there. I would never want to dump gravel on any grass that I want to keep mowed.
I've never thought about dumping it into my bucket. I can't imagine how much longer that would take, or how much more effort would be involved. In my opinion, getting it done is my main priority, and not dealing with rock mixed into the grass is just going to create more work for me.
I've seen where contractors will lay down plywood, but I've never seen anybody use a tarp. Even with plywood, there is damage to the lawn that has to be dealt with. When it's dumped on the driveway, there isn't any clean up.
UNUSED RAYTREE RMDM72S - 72" DRUM MULCHER (A62131)
UNUSED RAYTREE...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2018 Chevrolet Tahoe SUV (A61569)
2018 Chevrolet...
427888 (A61166)
427888 (A61166)
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61568)
2012 Ford F-450...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61568)
2013 Freightliner...
