3 point Chipper ????
/ 3 point Chipper ???? #1
TJP440
Member
Kubota b3200 & GR 2120
I'm in the market for a woodchipper and ran across these guys on sleaze bay. They have a machine somewhat similar to a Woodmaxx WM-8H which from my hours of research seems to be the top dog for my needs and compatibility with my B3200 (23 PTO HP)
They claim to have been in business 20 years and through the wording of their ads/website they some what lead one to believe their units are made in Canada. They also claim The Woodmaxx is a knockoff of their unit? Their website sounds like it was written by an experienced used car salesman.:rolleyes: THEIR VERSION LINK
The price is attractive BUT sounds a bit 🎣🎣🦈
So I thought I'd ask here for any experiences with them good or bad. They sell a lot of other implements as well.
My need is not regular but running out of places to put the limbs etc when the trees fall or die not to mention some have grown to 70+ feet tall.
TIA for any input
/ 3 point Chipper ???? #2
I see one concern. With all those features - it's more than a remarkable price. Hydraulic in-feed, heavy rotor, easy access to knives, HD hydraulic motor. $2895.
A comparable Wallenstein - $10,450.
I hope somebody with product experience posts here with actual knowledge of the product.
/ 3 point Chipper ???? #3
TIA for any input
is this the same company?
yelp reviews
/ 3 point Chipper ???? #4
How does one access the knives? or clear a jam? I don't see a hydraulic infeed. With only 23 hp you will be well served with adjustable infeed. I bought a Woodland Mills WC-88 several years ago. This unit doesn't compare well to it. (just ask me) Not even for the price difference.
yelp reviews
Would appear as so, A Big THANK YOU for that. The response I received from them on Ebay concurs with the yelp postings IMO
/ 3 point Chipper ???? #6
It's similar to a Woodmaxx 8M, not 8H. The infeed power is mechanical not hydraulic. So it's only one feed rate and the engage/disengage mechanism might be a little funky. I have not used one so I don't know for sure.
I have a 8H on a 37hp tractor and I can easily bog it down. 23hp is not enough unless you are only chipping small branches, like 2" and less. If that's what you're doing the large throat will still be a benefit as you'll have to trim less.
The 8H is about 1100 lbs and this is probably similar. It sticks out a ways too making the weight have more effect. It's noticeable on my 6000 lb Branson. It might be too much for your tractor.
On an 8H you access the knives with doors on either side of the rotor housing. This appears to have similar doors.
It's only $300 less than a Woodmaxx 8M. I'd go with a more well known and supported Woodmaxx or Woodland Mills unit. A 6" might be more appropriate both for HP requirement and weight, and cost a little less too. Both companies make them.
/ 3 point Chipper ???? #7
I have the same chipper but mine is from jinma. Bought from a shop out of Tennessee. Haven't had any problems. Tighten every bolt when you get it. Mine was like $2300 delivered to a freight dock in town. I run mine on my 32 PTO hp tractor at about 1800rpm. It will chip a 8" pine tree. I mostly chip brush, the outdoor burners gets the rest. I would buy it again.
I want to thank all that responded and give an update. I went with the Woodmax WM-8H. And for any one looking for one, they are running a 30% 😳 off sale and 🤫🤫PSSST! free shipping If YOU ORDER ONLINE.
Lots of other things on sale as well 🍻🍻
/ 3 point Chipper ???? #9
I am close to pulling the trigger on a Woodmaxx 8” chipper. Torn between the Mx series and the WM. The MX has a hydrostatic indeed and seems to have less hydraulic hose clutter. Maybe a little more user friendly. But the price on the WM is very attractive.
The WM 8H is hydraulic feed :) The WM-8M is not. Both are long standing imports from China :( I have done extensive research and all have good reviews. There is a YouTube video of a review at 500 hours.😳
He says little to no problems other than regular maintenance.
I also looked at a bunch of other brands, reviews, videos etc.
The current sales pricing cinched it as i was also looking at some used units that sold for more than the sales price. on had almost 100 hours on it 😳
All of the WX series are US made
/ 3 point Chipper ???? #11
That is exactly where I’m at. I’ve been searching for several months for a good deal on a used hydraulic feed chipper. The price on the WM hydraulic feed is a no-brainer. I ordered it today.
Smart man ;)
it was a good thing I missed out on several used units that sold for more than the sale price with no shipping. Most were 3-10 hours, a few had been outside and one had almost 100 hours on it.
this was a DEAL!! 🎯🍻
/ 3 point Chipper ???? #13
I bought my Wallenstein BX62S - Oct, 2013. $4500. This model isn't made any more. I've put over 400 hours on this unit - chipping the small pines I clear from my stands. The pines are all small ( 1" to 6" on the butt ) and freshly cut. There is no dirt on these trees - after ten years the blades are still sharp as razors.
Mine will chip up to 8". However - have you ever tried to man handle a green pine that is 8" on the butt. I do well just grunting a 6" pine - up and into the chipper.
There is one advantage to having/using a larger chipper. The rotor will usually be heavier. More inertia - easier chipping.
/ 3 point Chipper ???? #14
I’ve had a WM-8H for 10 years now. 9 years were on my Boomer 30 with 28hp engine, 22.5hp pto. It chips nearly everything I’ve put through it. It can handle anything that isn’t firewood, though I may have to slow down the infeed or pause it a few times on a big log to let it recover.
That said, I got a 47hp LS last year, with 38 hp pto. It is much faster.
I wouldn’t be afraid of using the 8H on a 23hp tractor if it’s all you have. It won’t be as fast as a high HP tractor, but it will still work.
Only complaint on it is I wish I could use more than 20% of the hydraulic flow adjustment. It’s 0 to 100% speed in just a small portion of the travel.
Thanks for the input. My unit is 32 HP with 23 at the PTO so I'm hoping it will do fine. Per WM 19@ the PTO is their recommended minimum. Main use will likely be for long limbs 3" or under with branches. ;)
Om your comment regarding the flow adjustment, I don't have my unit yet so I can only assume you are referring to the hydraulic feed rate. If so I might contact Woodmaxx tech dept and ask about it as in all the research I've done yours id the first comment on it :)
TPL MECHANICS BODY LUBE SKID (A62130)
TPL MECHANICS BODY...
UNUSED 250 GALLON FUEL TANK (A62130)
UNUSED 250 GALLON...
Toyota 2FGC20 4,000lb. Propane Forklift. (A61567)
Toyota 2FGC20...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
