Measuring for box blade
/ Measuring for box blade #1
nsmustang55ol
Member
2023 Kioti CK2620
I got my rotary cutter, found a deal on a 2022 RCR1260. Now I’m looking for a box blade. I read you want the box wider than the rear of tractor in order to cover tracks. I’ve seen a lot of 5’ box blades on Kioti CK2620’s. When I measure my rear tire width,from outside to outside, total width is 63-64” so would I need a 66” or a 72”? I got a good lead on a killer deal for a 60” but don’t want to regret it. I have a 2023 Kioti CK2620 with R14 tires.
/ Measuring for box blade #2
Big advantage to cover your tracks?
If your BB is much narrower than your tire spread, and you pull in one alley repeatedly, your tires will soon be up on narrow ledges and the centered BB will not touch the ground.
Tractor tire weight will mash down minor differences of 1" to 1-1/2" per side.
In the attached photo, two years old, the 60" wide community burn pit is now 40" below grade. You can't do below grade work like this if your Box Blade is narrower than tractor's tire spread.
Note: Bush Hog (brand) Rollover Box Blade.
/ Measuring for box blade #3
Your CK2620 has a bare weight of 2,650 pounds, motivated by <25 horsepower.
All things being equal, which they seldom are, a 66" wide Box Blade will amply challenge your tractor.
Sooooooo……….60”?
/ Measuring for box blade #5
Post a picture of your rear wheels please. Also, a full rear view without any implement.
/ Measuring for box blade #9
I have a Bush Hog 720 ROBB. Pulled behind my Kubota M6040. The rear tires are 80 inches - outside to outside. I've used it several times to move dirt and dig trenches. I could see a problem if I wanted a trench just 72 inches wide. The ROBB is 72 inches wide.
However - I've never been in that situation. The only "trenches" I've ever dug are MUCH wider than 72 inches. Actually they are open pits used to bury trash. My ROBB works just fine for this.
So....... The simple answer. Since your rear tires are 63" or 64" wide - digging a 60" wide deep trench will be a problem. If you need a deep trench - it's going to have to be as wide as your rear tires. A shallow trench - 60" will be OK.
/ Measuring for box blade #11
I run a 60" on my CK2610 and have yet to run into a situation where it's been a problem; however, I had the blade when I purchased the tractor. If I were buying new I'd probably opt for a 72 inch, but if the price is right I don't think you'd regret the 5' box.
Don't over think this. Buy a box blade that will cover your tires. Your tractor is capable to do the work.
I got a lead on a 60” Frontier BB5060, for under $501 without rippers, or a 60” Heavy duty atlas with rippers for 600$. 66” doesn’t seem to common in the used market. Not for those prices atleast.
/ Measuring for box blade #13
Ideally 66" would be good, but go as heavy as you can find in any case. I believe ditching or changing the angle of the cut easily kind of requires covering your tracks? I've got a 7' on a 6' wide tractor which is all I've ever used, and it never seems to wide when moving dirt. Ditching is easy with it too by just tilting it couple inches low on one side and take a few slices on each side until the tractor feels tippy.
/ Measuring for box blade #14
What did you end up getting? Your tractor will easily handle a 6' box blade BTW.
/ Measuring for box blade #15
I have a 6' box blade and have used it on a kubota b8200 (19hp) no it wont drag all the scarifiers at full depth or drag a full box in my packed stone driveway. But it did work decent enough that when that 19hp tractor was my old tractor for a few years i didnt want to get a smaller one. I now use it behind a tc40 with no issues.
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
