Favorite diesel can?
/ Favorite diesel can? #101
Good suggestion, i.e. 3 gallon size VP Racing Fuel container. I went to snap up a couple of those BUT - the extra 'tax' of $9 for a hose plus another $5 for a hose bender, killed my interest. Perhaps you can recommend a place other than Amazon to buy them at a better price?
I bought them from the following, don't recall if it was a sale but it was a few dollars cheaper for each but everything has gone up! I bought 4 of them and that made the reasonable shipping fee a bargain...
/ Favorite diesel can? #102
Thing is when we first got the larger tanks, the truck didn't run. I made my kids run back and forth with the three diesel cans and gas cans we had until the tanks were full. After they did that they decided it might be easier if they just fixed the truck as it was getting old. Teen agers are fun.
/ Favorite diesel can? #103
I picked up a L shaped 50 gallon auxiliary fuel tanks for a pickup at a garage sale for $50.00 and a HF circular hand pump and put it on pickup box trailer that I can run down and fill with fuel then I can either pull it into the field or pull up to the trailer to fill the tractor.
/ Favorite diesel can? #104
The issue I have with fuel cans is getting contamination into the fuel system. Even if you have to make several trips to fill up your fuel storage tank, its filtered when it comes out. Also, if you are using cans to fill your equipment you're sticking the spout in three times. I try to wipe the spout off, but it's a pain. Like i said teenagers are fun had this conversation. You dump it into the tank and pump it into the tractor, run it through that nice filter. The filter on the storage is your friend, money in the bank...... Equipment dying in the middle of a field, because my nit wit kids were too lazy to wipe the fuel can spouts off, every time they filled the lawn more all summer long.
The original post has an 11 gal tank, i would not recommend containers of any sort, not with the amount of fuel he is going through it is asking for trouble.
/ Favorite diesel can? #105
I currently have two style, the Sure can with the spout that pivots from the bottom of the can which is handy as I can set the can on the tank, bend the spout into the filler neck and just hold the handle down. The other is one of the other push button style cans, that one is ok but I much prefer the Sure Can. However, I am looking to buy a larger container with a transfer pump. My tank only holds 6 gallons but it goes through the fuel quick enough to where the cans are annoying. Some helpful suggestions in this thread so far.
/ Favorite diesel can? #106
Here is the thread where we got them 6 years ago. Most of the things i found wrong they have corrected. The big rub was the filter. One we bought did not have it and we added it. At the time these where the only ones making a plastic tank and I wanted plastic. The ones on amazon look really close.
The one for gas maybe a one of a kind. When we bought them, we bought them left over from a show the importer had them in and i am not sure they ever jumped through the hoops to get them approved for the us. Not had any issues with the gas one. The diesel one the hose rotted, and we replaced it and we added a fuel filter right out of the gate.
/ Favorite diesel can? #107
I will be using my 2.5 gal oil plastic oil cans
no worry about getting anything extra for them
and very easy to fill tank on top of hood
willy
T6 at wally world was $23.52 gal
Have you found a spout that screws onto the 2.5 gal oil jugs?
/ Favorite diesel can? #108
I have a 30 gallon fuel caddy and it works but does require the loader to load/unload from the truck. I have been toying with the idea of buying a larger transfer tank and mounting it onto a small trailer. So, it’s easy to hook up to a vehicle and tow to fill it.
/ Favorite diesel can? #109
I recall a discussion including fuel tank trailers and potential hazmat requirements, but I don't recall if there's a small size that avoids this.
/ Favorite diesel can? #110
I can’t imagine that using transfer tanks like are designed for truck beds would trigger hazmat markings. They are used in truck beds routinely.
/ Favorite diesel can? #112
That's the DOT number I found when shopping for my 108 gallon transfer tank. I made a pallet for it, and load it up 2-3 times per year for filling.
I have read somewhere here on TBN that you can be dinged by law enforcement for failing to have an "Off Road Diesel" label on it, assuming it's filled with off road.
UNUSED REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED REMOTE...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A62130)
UNUSED SWICT 60"...
UNUSED KIVEL 48" PALLET FORKS (A62130)
UNUSED KIVEL 48"...
2019 Kuhn GMD3151TL Disk Mower (A63116)
2019 Kuhn...
UNUSED RAYTREE RMSG29 HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
