[KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance
   / [KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance #61
The guy that brings my gravel says he brings about 18,000 lbs and it's probably 13 yards. He runs a 15 yd truck.
Yeah... I realize I should not stress too much about cubic yards and tons. After a few loads I'll learn if the load seems light or adequate.
Thanks for the feedback.
   / [KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance #63
So,
1) those numbers clearly aren't right; the weight is anything from a low of 2,410 pounds per CY (1.2 tons) to 2700 lbs per CY (1.35 tons).
2) I'm going to have to mention my ignorance; Freeze Thaw, all advice I have given I based on personal/professional experience in North FLa and South-South Centralish GA. I have Glanced at the Town of Catskill NY Minimum Road Specification, but I'm no expect in snow or ground that freezes.
Their Spec for Roads; blade subgrade and roll with min 8-10 ton roller until "no creeping or weaving appearance ahead of the roller"; then place "gravel base" in 2-5" lifts.
So, for a road, they accept 10" of base material; so what I'm saying is, in Florida; a typical county road would likely spex; 12" of stabalized subgrade LBR40 (this is native soil, with rock or clay mixed in, the LBR40 is basically just a kinda dirty-sand/rock/clay mix; not pure sugar sand); then 6"-10" of Limerock base (LBr100. any clean roadbase should meet that LBR, but not stuff that has sand or over burden mixed in); So; our base thickness is pretty similar. Based on the similar situations, specs, and your low traffic volume; I "think" 4" of this crusher run will be fine on top of a firm subgrade. But what I am saying; specifically pay attention to what other northern/NE people say.
  • Good Post
Reactions: D&D
   / [KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance #64
I did get a quote by the weight: 15 yards or 2 ton = $375
15 yds = 2 ton
15 yds = 4,000 Lbs
1 yd = 266 Lbs
Something seems off. Either my ton>Lbs conversion (1 ton = 2,000 Lbs) is wrong or this is a very light way cubic yard of crusher run.
I'll call them tomorrow again to clarify this quote.
Hopefully, it’s 15 yds = 20 tons. For basic math, one yard covers ~ a 10’ x 10’ area, 3” thick.
What you had, 8100sq.ft. X 0.25 (3”depth or 1/4 foot)=2025 cu.ft./ 27 = 75 cu yards
   / [KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance #65
Arguing with truck drivers on what percentage fill a truck is, of a theoretically cubic capacity is no fun.
If you are worried; a full truck should have a nice center front mound, small front corner holes, and pretty decent "holes" at the back corners. If there is no center mound, above the sideboards, your getting cheated.
Doesn’t that kinda depend on how it was loaded and the road conditions between load and unload points?
Are there any (tandem +) trucks running the roads that can’t tell (show) you what there loaded weight is?
   / [KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance #66
This is normally is issue only with dirt, or debris. A barrow pit isn't going to have scales; storm debris its also a big deal to track cubic yards of debris removal.
Nowadays; many JD-544 class loaders and larger have an electronic scale, that can weigh every bucket load. Sure, not DOT accurate, but when we are talking about $4/ton material for dirt, that's good enough.
   / [KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance #67
Once it's dry out there, if the area you need gravel is pretty close to level and the first pictures represent it well, the driver should be able to tailgate the majority. I built about a 450' driveway last year and had 4 loads of SB2 Grade 7 tailgated on it. It ended up being deeper than it needed to be, 3 loads would probably have done it. Tailgating just means the driver will chain the tailgate so it will only open a few inches and drive while its dumping. It ends up about the width of the truck and the depth can be controlled by the speed of the truck within reason. If they do a good job with it, any type of rear blade would be ok.
Around here SB2 Grade 7 is called road base. It's probably 2-3 inch stone with the fines in it. It packs really well and stays put. I built up and crowned my base with shale that I dug on site then topped it with the road base. So far we have had some long, heavy soaking rains and it did not effect the driveway.
That's a nice driveway. Not having any trees means it gets alot of sun and dries out alot quicker than a tree covered driveway. It does make a prety big difference.
   / [KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance #68
Yea, not DOT accurate but the air suspension gives a “good estimate” of weight on the truck.
You are absolutely correct. called our local sand&gravel and they clarified the quote: 15 yards @ $375 and approximately 20 tons.
He confirmed they sell by the yard and not by the weight. So my math was off by a factor of 10! Ouch!
   / [KUBOTA B3200] Grader Blade / Box Blade Recommendation for Driveway Maintenance #70
Ok, that's what I assumed. You are lucky, those are great prices for delivered material.
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A60460)
2015 Kenworth T880...
gps trailers (A56859)
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
Ryan Walk Behind Aerator (A59228)
Ryan Walk Behind...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
