Used hydralic fluid and diesel for trailer deck?
/ Used hydralic fluid and diesel for trailer deck? #1
paulsharvey
Super Member
Hawthorne, Fl
Kioti CK2610 HST
I know there have been 500 threads about treating trailer decks already. Most seem to be about useful motor oil; either straight or cut with kerosene, ATF, or diesel. I've got about 5 gal of hydralic fluid sitting in a drain pan, and was just thinking about rolling it on trailer deck, maybe with about a gal of diesel to thin it out. My only concern is would hydralic stay slick on the wood deck?
Really the best wood treatment I've ever really seen is the diesel bucket on a paver you clean shovels in. The broken down AC and diesel do a great job on shovel handles.
/ Used hydralic fluid and diesel for trailer deck? #2
Just a guess but most any petroleum product will make a wood deck slicker. I've applied linseed oil on my trailer deck. Get it boiling hot - apply with a roller. It really soaked in. But it did make the deck slicker.
/ Used hydralic fluid and diesel for trailer deck? #3
Use boiled linseed oil. You can cut it with mineral spirits or citrus oil. Boiled linseed oil will be tacky for a month but eventually it will cure to a hardened surface. Sun helps, and there are other tricks to make boiled linseed oil cure faster. That is the most common cheap finish on old wood decks. If you buy the boiled kind of linseed oil you can put it on at any temperature. Do not buy unboiled type, boiling is a controlled process.
That is much better than motor oil or hydrauic oil which stays messy forever and never cures.
As for what to do with the old oil, I've heard that places that sell it are required to dispose of the used oil.
Around here, some do and some don't.
rScotty
/ Used hydralic fluid and diesel for trailer deck? #4
if using linseed take extra precaution to handle used oil soaked rags, rollers, etc properly. they go through a post use heating & can spontaneously catch fire in certain conditions. happened to me once, glad i caught the smoldering rags in time in the garage.
also as a footnote (others may have different results). being organic base, i've had wood products such as screen doors, etc, turn black in 6 months from i guess fungal or bacterial growth. may not make a diff in your application, regards
/ Used hydralic fluid and diesel for trailer deck? #5
Linseed oil is a prety crappy exterior wood Preservative. It allows mold and fungus to grow. If those can grow you know water is soaking into the wood.
/ Used hydralic fluid and diesel for trailer deck? #6
that's why i stopped using for exterior use. even interior, it will darken over the years
/ Used hydralic fluid and diesel for trailer deck? #7
I dump all of my used oil, engine, hydro, whatever, into the same jugs. I use the oil straight without mixing with anything on my trailer, snow fences, and anything else made of wood that won't be coming in the house. I coat the trailer every year. It is slick until dry. It will be slick when it rains. But it is not slick enough when dry to cause any issue and it generally does not come off on anything. I usually do it when I know there will be 2 or 3 nice, warm, sunny days to let it set.
/ Used hydralic fluid and diesel for trailer deck? #8
I use motor oil or used hydraulic fluid whatever I have an abundance of at the time but I try to cut it with an equal amount of diesel fuel. I try to apply it on a good hot day ( which where you and I are there is no shortage ) I use a paint roller on a stick with a roller screen in a 5 gallon bucket and it soaks in just fine, a mop will work to and a lot faster but IMO you waste an awful lot and definitely not as environmentally friendly.
/ Used hydralic fluid and diesel for trailer deck? #9
Use it, It doesn't make it slicker after it dries, it dry.
The trailer is only like 3 or 4 (maybe 5 at this point) years old, and between sun and rain, the 'non ground contact' pressure treated wood is looking worse for the wear. I'm not trying to get 50 years from the deck, but don't want to replace deck every 8 years either...
So, yeah, I figure I'll cut with diesel and roll.
/ Used hydralic fluid and diesel for trailer deck? #11
Brushing is really best for any exterior wood application. It allows you to work the stain/oil into the cracks in the wood and fill them up. Cracks is also where water can sit and rot will be the first to start.
/ Used hydralic fluid and diesel for trailer deck? #12
I personally prefer using a brush as well. Also lets me get the edges of the plywood which is more important.
/ Used hydralic fluid and diesel for trailer deck? #13
Just oiled the sideboards (deck plank wood) and plywood deck of my 6'x10' ramp-gate trailer. Then I did my 16' car/CUT hauler's 2x10 treated deck. Plastic liner in a metal rolling pan and straight hydro from the last change. I used a thick nap roller with long handle and a 2" brush to easily cover all areas and get into the corners/edges where the roller wouldn't go.
It was a far bigger job to powerwash all the wood days before to prep.
Two weeks later I'd like to oil the decks again. Both trailers are 20 years old and have never had such treatment. They aren't the least bit slippery when dry, and look almost new. The KISS principle is working for me and sweeping leaves seeds and twigs that kind of stick after a rain are way more easily swept off.
It was 95 today; and we haven't had measurable rain in a month; dang grass is so crunchy it sounds like walking on rice crispies.
/ Used hydralic fluid and diesel for trailer deck? #15
I used BLO and mineral spirits a couple years back. A couple of coats.
At Lowes over by the cans of asphalt sealcoating stuff, they should have some large brushes that you can screw on the end of a broomstick. It's a nice back saver.
Might do it again this year if it ever stops raining.
Neither BLO or waste oil has UV protection so you'll still have some issues down the road.
/ Used hydralic fluid and diesel for trailer deck? #17
UV protection comes from a darker stain so used motor oil would have more UV protection than linseed oil.
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Komatsu PC200 Excavator (A60352)
Komatsu PC200...
JOHN DEERE 6140M TRACTOR (A62130)
JOHN DEERE 6140M...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
