TC35 no start issues
/ TC35 no start issues #1
Chuck750ss
Tc35
2005 TC35 NewHolland bought new, now has 1000 hours. For last 3 or so years, tractor hard to start if not run on a weekly basis. When it did start it would spit and sputter blowing white smoke. After it ran a very short while it would smooth out. Knew I was gettIng air but couldn’t tell where. Fast forward to a couple of weeks ago. Tractor refused to start. Had friend come help me and we started tracking down fuel lines, connections, etc.. when my friend cracked one of the fuel connections on the fuel lift pump, air squirted out. Turned engine over a few times, engine definitely trying to start. Tightened connection engine fired right up. So I have replaced the fuel lift pump. Engine will not start. Not even trying. Have traced fuel flow, know I am getting fuel to the injection pump.(have no idea if enough flow or pressure assuming if getting fuel to injector pump everything ok). Loosen one injector line , nothing comes out.
Verified that I have “juice” to the fuel shutoff solenoid. Can hear click when I turn on ignition key. Don’t know if that is shutoff actuating or glow plugs coming on.
Filter is new. Getting fuel to injector pump. No fuel coming out of injector line exiting injector pump.
Looking for ideas.
/ TC35 no start issues #2
By all means make sure you're getting power to the glow plugs, then check the plugs themselves. White smoke on start indicates moisture. It may be just condensation or it may be something more serious.
Not getting any fuel from injector pump.
/ TC35 no start issues #4
Looking for ideas.
You might try bleeding air at the injection pump. There’s a small banjo bolt at the very top of your injection pump you loosen a little while cranking.
Sounds good. Not familiar with “banjo” bolt. Could you provide a description? And would it be located towards front, center or back?
Thanks.
/ TC35 no start issues #6
Here you are , this is from a CIH dx35 but identical to yours I think. Bolt is to right and above fuel supply hose
/ TC35 no start issues #8
If your getting good fuel flow to the injection pump and nothing out I think you have found a problem. Be sure to bleed the **** out of the system before you proceed.
I believe there are small popit valves at the pump outlets for each injector. You really need to do more research on that injection pump because I'm sure it's not cheap to replace.
Bled that line. Verified that the fuel shutoff solenoid is working properly. No joy.
Got good fuel flow to the injector pump. Nothing coming out, aka, nothing from the injector lines when I loosen and attempt to start engine.
Tractor was running when I parked it a couple of weeks ago. I have replaced the fuel lift pump, but as far as I can tell it is working properly.
Anytime in the past when I changed a fuel filter, all I did was leve it slightly loose, turn on fuel valve and let fuel run through it for a short bit. Then tighten bowl nut.
Yes figure the injection pump has to produce a certain amount of pressure to send fuel to the injectors. what baffles me is that the engine was running fine when i parked it.
i have completely removed the injector line from the front injector on the injector pump. Getting nothing out of this. Zilch.
The only thing different from when I parked it is I replaced the fuel lift pump which seems to be working good. I have bled everywhere I know to bleed including the banjo bolt on the fuel intake at the injector pump. I know in the past that anytime I changed out the fuel filter I never had to bleed anything.
Open to any ideas as I am out of them.
I can put the old fuel lift pump back on but really don’t think this will solve the problem. BTW I did remove the fuel shutoff solenoid and checked it. It is operating just fine. Removed and checked at battery with jumper wir and then checked with the spade service wire before I screwed it back in.
Engine acts just like I am trying to start it with the seat safety switch not activated.(it is)
/ TC35 no start issues #11
Sounds like you’re covering everything, fuel to injection pump , air bled , shut off solenoid works. I wonder if you’re fuel rack is stuck in the injection pump?
That’s what it’s looking like. Wanted to eliminate everything else first.
/ TC35 no start issues #13
I can handle the pump repair if need be..
U might have broken gear teeth.. which will lock the rack up just that fast.. be thankful it locked in the s/o position and not wide open..
U can contact me thru here or my screen name at aoldotcom in your home mail server..
/ TC35 no start issues #14
Does that injection pump have a acess hole at the front cover? You can check that its non screwed up and actualy turning.
/ TC35 no start issues #15
I had a similar situation on a tractor I was working on..
New pumping plungers in pump, I overhauled it so I know it was put together correctly..
I cranked and cranked on that thing till the cows came home.!!
I loosened the inlet line and fuel would POUR OUT..
I did a compression test.. it was low but acceptable..
O/h the injectors..
Same thing, crank and crank..
As a last resort, I blew air FROM THE PUMP LINE BACK THRU THE FILTER AND INTO THE TANK..
“I knew” that wasn’t the problem because I had “plenty” of fuel at the inlet when I was bleeding it..
All of a sudden I hear a POP on my first blast of air..!!
“Something” was in the line restricting the the fuel flow just enough to keep the pump from pumping..
I thought I was getting enough fuel, but after that POP..I definitely was getting enough fuel.!!!
I turned the key and she roared to life..
I don’t recommend u start at the pump inlet seeing you have a supply pump and could rupture the diaphragm.. but I would pull the feed line off the supply pump, LOOSEN OR TAKE OFF the tank cap and give it a shot of compressed air.. and listen for bubbles..
Good luck
/ TC35 no start issues #16
O/h the injectors..
Good luck
I did that yesterday but to the line from the tank to the fuel filter.
My TC45DA acted like it was out of fuel, the tank had lots of fuel it, but none ran out when I pulled the line from tank to the fuel filter.
My tire inflater had enough volume and pressure to clear the line, so I didn’t have to tow it to the shop.
Update. Overnight the fuel rack plunger extended. I pushed it in, it stuck. Going to watch it. If it extends again, going put everything back together, leave ignition key on overnight (battery charger hooked up) see if it starts in the morning. If it does I can remove loader from tractor so I will have good access to injector pump.
I did blow back into tank. Looks like fuel flow improved but not 100% sure. Will blow back through line again before I try and start.
BTW, if I remove injector pump and don’t do anything other than try and free up fuel rack, I should be able to bolt back in place without timing anything, right?
/ TC35 no start issues #18
Yes, the pump times with shims under the pumps mounting flange.. they’ll either stick to the pump or to the block..
Do u have experience going into inj. pumps.?? U can cause WAY MORE damage than u can fix..
But good luck anyway..
Ford F-450 (A63689)
Ford F-450 (A63689)
JOHN DEERE 1705 - 6R30" VACUUM PLANTER (A64277)
JOHN DEERE 1705 -...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
GREAT PLAINS TURBO-MAX 1200 - 12' VERTICAL TILLAGE (A64277)
GREAT PLAINS...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
(10) New CATERPILLAR Keys (A65579)
(10) New...
