LS water pump
/ LS water pump #1
Billy Fischer
LS G3033
trying to buy a LS G3033 water pump----OR a place that will rebuild it (bearing replacement)----no reply yet from North Carolina LS company
/ LS water pump #3
LS manufactures for New Holland (among others). Check out the suggestion from Eagle1.
/ LS water pump #4
If that is the correct pump either using Messicks or your local New Holland dealer would be an easy way to go.
I replaced one on my Brason 8050 about 4 years ago the pump right around $460-470 plus shipping was $500.
/ LS water pump #5
Messicks shipping on just about everything is way over the top and why I won't buy anything from them. It's almost like the sell their stuff a bit cheaper and then make up the difference in shipping charges.
/ LS water pump #6
It may be a tiny bit more when it gets to me but I placed an order with them for a couple of pins and spacers for my old F2000 the package arrived in 3 days. My nearest kubota dealers would have had to order them and to avoid a freight charge I'd have to wait till their normal stock order came in.
The dealer that would likely have had the pieces in stock is a 35-40 minute drive each way and with the discount would have been a couple dollars less. But by the time I drove up there, sat and visited for an hour and drove back it would have killed the whole afternoon.
/ LS water pump #7
If its just a bearing can't you replace it? Take the
numbers off the bearing and check the net for one
willy
/ LS water pump #8
Guess I'm fortunate in that respect. If I need something from my dealer, they deliver it to the farm, no charge. It 'appears' on the back deck steps.
2022 Horizon (A55973)
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
MASSAGE CHAIR (A58214)
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2014 F-150 STX (A56438)
2014 F-150 STX...
Sdlanch 12'x20' High End Carport (A60463)
Sdlanch 12'x20'...
