Best Everything Attachments (EA) Alternative? Landscape Rake, etc.
/ Best Everything Attachments (EA) Alternative? Landscape Rake, etc. #1
jahmes143
Member
Parrish, FL
Deere 5R
Now that EA is out of business, what's the next best substitute for a variety of implements? Right now looking for a landscape rake and a blade that can be manually offset (to side of tractor). Quality is important, price is less important. Is Land Pride the next best thing?
/ Best Everything Attachments (EA) Alternative? Landscape Rake, etc. #2
Bush Hog makes sturdy landscape rakes, varying sizes and weights, though they're a little pricey.
/ Best Everything Attachments (EA) Alternative? Landscape Rake, etc. #5
I have - Land Pride, Rhino, Bush Hog, Wallenstein and Pittsburg. All are excellent implements.
I've found, thru experience, the lower quality implements simply do not hold up.
If you are serious about getting the job/project completed - it's important that you have an implement that is up to the task.
/ Best Everything Attachments (EA) Alternative? Landscape Rake, etc. #6
Land Pride makes a high quality landscape rake if you get the LR 37 series.
/ Best Everything Attachments (EA) Alternative? Landscape Rake, etc. #7
I just got a rear blade from Iron Craft. 7ft. It is pretty nice. My 7ft heavy duty landscape rake is a tuffline. It has been great. Paid a little more to get the heavy duty one but well worth it for a landscape rake. Tines are strong.
/ Best Everything Attachments (EA) Alternative? Landscape Rake, etc. #8
Here are my thoughts
Landscape rake
York - York Rakes, Dethatchers & Landscape Equipment | York Modern Corp. they make the best rakes with the most options.
Woods
Landpride
Good blades are made by;
Rhino / Bush Hog
Woods
Landpride
There are lots of great equipment manufactures out there besides Everything Attachments. EA made good equipment, but in most cases there was better equipment out there. What are you looking for in a rake? What are you looking for in a back blade?
If money was not a concern and I had a JD 5R then I would go for one of these back blades with a gauge wheel. They are all vastly superior to the EA back blades.
Rhino
1540, 1700 lbs
2500, 2120 lbs
Bush Hog 225, 2120 lbs
Woods RB96.60, 730 lbs
Woods RB850, 1233 lbs
Landpride RBT4596, 1130 lbs
I have no loyalty to equipment manufactures. I have Alamo, Bradco, Ford, Gill, Greenline, Howse, Howard, Massey Ferguson, Stout. My back blade is a Ford 785A made by Arps and it has manual offset which was a criteria for me so I could reach over and clean ditches out without getting in them.
Post what your criteria is and folks will offer suggestions that will either fit your criteria or "buy what I have because its the best".
/ Best Everything Attachments (EA) Alternative? Landscape Rake, etc. #10
Regarding rear blades. I had a HD rear blade for both my tractors. 42+ years using a rear blade. Currently it's a Rhino 950 @ 1000+ pounds - seven feet wide.
A rear blade can be a real PITA for grading a gravel driveway. It's great for snow removal and cleaning out ditches. The problem is - when the front tires on your tractor go UP - the rear blade goes DOWN. And vs versa. Gauge wheels supposedly help a lot. I do not know.
I know it's a real game - trying to keep the rear blade grading a smooth path when going over lumps, bumps and whoop-de-doos.
I have a LPGS (land plane grading scraper) with scarifiers for maintaining my mile long gravel driveway in the summer. I also use my ROBB( role over box blade) for driveway maintenance. The LPGS is easy to learn/use. Just drop and drag.
I never have to grade the entire length of my driveway. Just a spot here and there along its length. Yesterday I graded two spots with the LPGS. They ended up flat and smooth as a pool table. That will be it - until this time next year.
I don't have gauge wheels for my Rhino rear blade. I'm not too sure that this type of setup would break the crust that forms when my driveway dries out. The surface is a combination of gravel, sand, silt and volcanic ash. The surface becomes as hard as concrete. I use the scarifiers on the LPGS if I have to break this crust.
/ Best Everything Attachments (EA) Alternative? Landscape Rake, etc. #11
If you have a small tractor, like under emissions, even TSC type attachments won't be harmed by your tractor.
See a tractor dealer for what you can't find at tsc.
Hi. You joined almost 7 years ago, and this your first post. A belated welcome to TBN.
Thank you! A longtime lurker :)
Thank you. That one is currently at the top of our list. If for no other reason, they're the closest dealer within a few hours (we live extremely remote in CO)
- We do some small rock (under 4") from pastures, with occasional larger rock (get off tractor and put in bucket).
- Form poop piles in pens and remove with tractor bucket.
- Remove small rocks and manicure horse arena.
- Light brush piling, including small bushes and sticks
- Clean ditches, mainly pulling gravel out of ditch back on to road
- Maintain crown in gravel roads running throughout ranch
Tractors are 40HP and 55HP Kubotas.
We've bent the Tractor Supply rakes, so need something more heavy duty.
2022 Ditch Witch C16X 36" Dig Depth Trencher (A64047)
2022 Ditch Witch...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
2015 SKY TRAK 6036 TELEHANDLER (A59910)
2015 SKY TRAK 6036...
2021 John Deere 3046R Tractor Loader (A63116)
2021 John Deere...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
