Do You Have a Tractor Shed/Barn?
/ Do You Have a Tractor Shed/Barn? #21
When you live in a 300 year old house, you learn to make due and build within what's already here. So, about 10 years ago I converted this 1770's carriage barn to a workshop, adding a second floor within the existing envelope, insulation (spray foam), heat and air conditioning, electric service, etc. Expanded the original 20x30 to two floors. There's a 300 sq.ft. unheated shed salt-boxed onto the back, where the tractor, mower, and most of the implements live.
Only thing I'd do different, if I could do it all over again, would be to add a third garage bay to the front, make it 40 x 20, and then blow the one on the right thru to the back of the salt box, so I'd have one 30 ft. deep bay to store my boats. Now I have to rent space for that, and I've set up the electric in a way that basically precludes doing it now.
/ Do You Have a Tractor Shed/Barn? #22
I got VERY tired of lowering the roll bar. So I built this tractor car port and now all is fine. I never closed off the far end - allows me to enter/exit from the front or rear. Allows me to have a canopy also.
/ Do You Have a Tractor Shed/Barn? #24
Well… now I’m not gonna post a pic of my puny 16x20 shed.
You have a beautiful setup! (y)
This entire house, barn, property can all be described as "beautiful but dysfunctional." It has miles of curb appeal, but isn't the most practical space in which to live. :D
/ Do You Have a Tractor Shed/Barn? #25
My dream has always been a 40x120 with bays plus a large gable end door.
A farmer has this one and he can take any rolling stock out the gable end as the middle is an aisle to the gable end.
The end is a very nice 36 wide x 40 deep shop with lift.
/ Do You Have a Tractor Shed/Barn? #26
We have a 100 year old dairy barn that has been converted to horse stalls. No equipment goes in it. I have had two friends that their barns burned down from hot equipment. Since our barn is so old, the equipment, even lawn equipment does not get housed in it. It's irreplaceable.
That said, the tractor is too big for any other outbuilding. We had plans to remove and replace the one with the truck and other equipment in it, but life events got in the way. It would be nice to replace it as it too is over 100 years old and is in need of repair. At the rate we are going it may never get replaced. Maybe the next owner has a project.
So the tractor and implements sits outside and IMHO, that is not good,
/ Do You Have a Tractor Shed/Barn? #27
My attached garage and house sit at a 45 degree angle to each other. My little John Deere 318 and later Kubota BX24 would sit in the corner. With the BX 24 attachments, loader, backhoe, box blade etc. it was tight and required removing attachments and a game of tetris at the end of each day.
Finally, we added a third stall with a 10' door for the tractor and attachments. It has made it so much nicer to be able to just drive in at the end of the day, shut it off and walk away.
Doug in SW IA
/ Do You Have a Tractor Shed/Barn? #28
Not yet but in the beginning stages of building a barn this year.
/ Do You Have a Tractor Shed/Barn? #29
lol... "old" is relative! The oldest part of our house is 290 years old this year, with two of the three major additions being very substantially older than your dairy barn. I have no qualms about storing my tractor and mower in a 1770's carriage barn, at least it's away from the house.
There actually is evidence the barn had a fire once, maybe 200 years ago for all I know, one post and some of the siding around it was charred from some past experience. I do know that tractors have been stored in this barn only since 1986, when the larger dairy barn was taken down, so the fire did not come from a tractor. Best guess, someone probably once had a stove installed there, to close to combustibles.
/ Do You Have a Tractor Shed/Barn? #30
There was a small pole barn, with Masonite siding that was coming apart and metal roof that leaked on our property when we bought it 25+ years ago. That's where I keep my tractor. Here's a shot of it with my tractor in it as I was half way through replacing the siding and roof.
Before I started that I build an open front shed for all my implements. Here it is, partly filled with building materials for the barn remodel.
There was a septic tank there from when there had been a mobile home on the site and it's a ways from the house, so I included a restroom on the end. It also serves as a varmint-poof place to store seeds, and is heated above freezing so we can store garden chemicals there. That's handy since the garden is about where this photo was taken from.
/ Do You Have a Tractor Shed/Barn? #31
Maybe a lamp?
/ Do You Have a Tractor Shed/Barn? #33
Started out with a 20x21 carport that we outgrew. A neighbor had a tree land on his during a hurricane, so we took the uncrushed half and added a 12' lean-to to the smaller one. Had a large 26x50 drive through built a few years ago, all working out well, and all out of tree falling distance!
Crushed
/ Do You Have a Tractor Shed/Barn? #35
/ Do You Have a Tractor Shed/Barn? #37
A picture of my 28’x30’ shop but I don’t keep the tractor here, just two of our cars. The tractor sits in the garage at the house. I do work on everything in here though.
/ Do You Have a Tractor Shed/Barn? #39
Could you elaborate on that a bit. My son would ask a lot of questions. He always ended up wanting the long answer.
/ Do You Have a Tractor Shed/Barn? #40
Built a Pole Barn 6 years ago, uninsulated, concrete floor, 40x72 fourteen-foot walls. Two twelve-foot doors and one ten.
Keep a wheel-house (icefishing), tractor, RTV and trailers inside. Boats in the winter. I read on a thread here once, that you will pay for a pole barn whether you have one or not, owning toys. I agree, all my equipment look like new staying indoors year round.
Built a mezzanine around 20'x40' to keep all the stuff I was moving around on the concrete floor. All that little stuff now sits up there. Boat trailers underneath. Should have built 40x80. Cat was rented.
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2017 Case CX145D (A62177)
2017 Case CX145D...
2019 Ford Escape SUV (A61569)
2019 Ford Escape...
New/Unused 13,000lb Electric Winch (A61166)
New/Unused...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
