New to me TC29D cranks & won’t start
   / New to me TC29D cranks & won’t start #21
Are you holding the key at the GP position for at least 10 seconds BEFORE proceeding to the crank position?
The glow plugs are on a timer it seems like
The GP dash indicator light cycles on the run key position for between about three to seven seconds then turns off and clicks
I’ve got a compression test kit in hand and a continuity meter as well. I’ll see what I can find out about the GP test and I’ll compression test while each GP is out for the test
   / New to me TC29D cranks & won’t start #23
You do know that you can’t use a compression tester for a gasoline engine, dont you.?
The gauge doesn’t go high enough..
Good luck with the testing..
   / New to me TC29D cranks & won’t start #24
As an owner of a healthy TC 29 D I can tell you for a fact that that engine will start with no glow plugs no problem. Mine sits outside all year, and it has started in -0 temperature without a block heater.
Compression test procedure is correct, disconnect power to glow plugs, battery charger is only there so you don't kill the battery while cranking. 🍻
   / New to me TC29D cranks & won’t start #25
A gas engine makes anywhere from 8:1 - 14:1 compression you most certainly can check the compression on a gas engine.
How does that dumb ass statement pertain to a diesel tractor.
Compression tests are done to check the health of gas engines all the time.🍻
   / New to me TC29D cranks & won’t start #26
Talk about dumb ass statements.
I have seen nothing in this thread that has said compression tests can not be done on gas engines.
I did see one that mentions that the compression gauge for a gas engine will not have enough range of scale for a diesel with it's higher compression ratio of18:1 - 21:1.
   / New to me TC29D cranks & won’t start #27
Not encouraging inflammatory rhetoric, but if thepumpguy had worded his response better there would not have been a misunderstanding.
It should have read "you know you can't use a gasoline engine compression tester on a diesel engine..."
The subject matter was the testing of a diesel though.
   / New to me TC29D cranks & won’t start #28
Read post 23 Lou. Or can't you read. It say you cant use a compression tester on a gas engine.
   / New to me TC29D cranks & won’t start #29
It is apparent you can’t read or maybe comprehend. Post 23 does not say you can’t use a compression tester on a gas engine.
It clearly says you can’t use a compression tester FOR a gasoline engine. And then goes on to explain the gauge does not read high enough. This was a heads up post as the OP stated he already had a compression test kit.
   / New to me TC29D cranks & won’t start #30
All compression testers have gauges that go from 0 - 300 psi. The only thing that's different in the gas diesel testers is the adapters in the kit.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2022 John Deere Z930M (A57148)
2022 John Deere...
