New to me TC29D cranks & won’t start
   / New to me TC29D cranks & won’t start #21
Are you holding the key at the GP position for at least 10 seconds BEFORE proceeding to the crank position?
The glow plugs are on a timer it seems like
The GP dash indicator light cycles on the run key position for between about three to seven seconds then turns off and clicks
I’ve got a compression test kit in hand and a continuity meter as well. I’ll see what I can find out about the GP test and I’ll compression test while each GP is out for the test
   / New to me TC29D cranks & won’t start #23
You do know that you can’t use a compression tester for a gasoline engine, dont you.?
The gauge doesn’t go high enough..
Good luck with the testing..
   / New to me TC29D cranks & won’t start #24
As an owner of a healthy TC 29 D I can tell you for a fact that that engine will start with no glow plugs no problem. Mine sits outside all year, and it has started in -0 temperature without a block heater.
Compression test procedure is correct, disconnect power to glow plugs, battery charger is only there so you don't kill the battery while cranking. 🍻
   / New to me TC29D cranks & won’t start #25
A gas engine makes anywhere from 8:1 - 14:1 compression you most certainly can check the compression on a gas engine.
How does that dumb ass statement pertain to a diesel tractor.
Compression tests are done to check the health of gas engines all the time.🍻
   / New to me TC29D cranks & won’t start #26
Talk about dumb ass statements.
I have seen nothing in this thread that has said compression tests can not be done on gas engines.
I did see one that mentions that the compression gauge for a gas engine will not have enough range of scale for a diesel with it's higher compression ratio of18:1 - 21:1.
   / New to me TC29D cranks & won’t start #27
Not encouraging inflammatory rhetoric, but if thepumpguy had worded his response better there would not have been a misunderstanding.
It should have read "you know you can't use a gasoline engine compression tester on a diesel engine..."
The subject matter was the testing of a diesel though.
   / New to me TC29D cranks & won’t start #28
Read post 23 Lou. Or can't you read. It say you cant use a compression tester on a gas engine.
   / New to me TC29D cranks & won’t start #29
It is apparent you can’t read or maybe comprehend. Post 23 does not say you can’t use a compression tester on a gas engine.
It clearly says you can’t use a compression tester FOR a gasoline engine. And then goes on to explain the gauge does not read high enough. This was a heads up post as the OP stated he already had a compression test kit.
   / New to me TC29D cranks & won’t start #30
All compression testers have gauges that go from 0 - 300 psi. The only thing that's different in the gas diesel testers is the adapters in the kit.
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
