Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,075
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've got a Stihl backpack blower, the 2 stroke variety.
On starting, I always choke it & pull once/twice until it sputters and then turn choke off and it usually (99.999999999% of the time) lights off.
Used it last weekend and did my usual routine. One thing different though... I was worn out from all the outside activity and forgot it out there. Storm was moving in so I simply moved it under the covered patio area (full roof). Things don't get rained on there but I'm sure they might get damp/wet from rain overspray.
Last Saturday, one week later I pull it out (of garage, I had already taken it back to garage a day after storms)
Bottom line...it will NOT start.
Symptoms:
Spark plug: Pulled out, it's sparking, swapped with another working one, nothing
Air filter: Looks clean, had a bit of stuff in it but I've tried to start with air filter on AND with air filter off so I know it's not a clogged air filter
Fuel filter: Pulled out for visual inspection, tank looks clean to the degree I can see inside there, nothing visible on fuel filter clogging it
Process: I've pulled & pulled starter and nothing happend. I pulled plug out and some vapors came out of plug suggesting to me the fuel is indeed getting into chamber and atomizing. I return plug & pull...I get a faint ignition sound as it sounds like the piston fired once or maybe twice...then nothing. I pull again...nothing. I get nothing until I remove spark plug and put it back in. Almost as though I'm allowing fresh air inside BUT, my air filter has been on AND off so I can't think it's any obstruction.
This partial sparking symptom is the same with either spark plug installed. The plug has come out wet so I initially thought I flooded the engine. After it sparked & sputtered the first several times (after I took plug out EACH time) I figured any flooding was over and it would start. Nada. I might add I also pulled the cord with the plug out to help air out any fuel that might indeed be in there.
The top of the piston head, which you can only see a bit of through the spark plug hole, appears to be damp which is why I thought it flooded.
I've not taken anything apart deeper than the air filter & spark plug. I'm planning on dumping the gas out BUT, I'm using the same gas that I've been using and was working fine just last week. Same can, same batch of mix.
I'll admit I'm somewhat baffled... I seem to be getting fuel, ignition and compression.
Any thoughts? Oh... I've wondered about an obstruction in the exhaust pipe... perhaps a dauber or something got in there and created a mud nest while it was under the roof??? If so, would that KILL the engine or as I'd suspect, just make it run poorly??
I'm heading out shortly to fight this fight some more!
Symptoms:
