Multiple problems with 2018 New Holland WM50 (470 hours)
/ Multiple problems with 2018 New Holland WM50 (470 hours)
I found out it first of all needs a good cleaning. A mouse or something built a nest inside the dash and chewed through a bunch of stuff. The errors with the seat and brake is either a sensor or - can't remember the name of the part but i have it in my notes. - 3126 is the potentiometer, and the dealer talked me through how to drain water out of the fuel. I obviously need a new one of these, but I have to google how to get the steering wheel off.
/ Multiple problems with 2018 New Holland WM50 (470 hours) #12
If you get the Shop/Service Manual, it should take you through removing the dash/steering/etc. Same thing that your dealer's mechanics use. Can your dealer order that for you? Or download to a thumb drive, & you print out the pdf at home. Mice can wreak all kinds of havoc. good luck.
I have looked online and didn't find a download of the service manual. I can ask my dealer about getting one. thank you! I talked to them again yesterday and they are going to order the parts for me. They are very helpful, just that they are over two hours away and I use my tractor almost daily for moving feed totes.
/ Multiple problems with 2018 New Holland WM50 (470 hours) #14
You usually need to buy the service manual, and it can be as much as a few hundred $$. It's worth it though if you do any work on the machine. A mechanic costs $125/hr. If you save two hours of mechanic's time over the entire life of the machine, the shop manual's paid for itself.
/ Multiple problems with 2018 New Holland WM50 (470 hours) #15
Have you considered buying the shop manual for your machine? I would imagine the codes would be listed in there. Or phone a dealer and see if they can help a bit.
Having a similar issue with a NH60 with 700 hrs. Been in 3 dealers shops and have spent almost $9,000 and it still won’t run. All sensors changed twice and both electrical harnesses replaced and needs a complete new fuel system according to the dealer. Been sitting in the tractor barn for 3 years.
/ Multiple problems with 2018 New Holland WM50 (470 hours) #16
Sucks to own ANY emissions compliant tractor and why I will never sell my pre-4 tractors (and why people don't want them used post 4 as well).
If I was to sell either of mine, they both command a premium price today I might add.
/ Multiple problems with 2018 New Holland WM50 (470 hours) #17
Yes. I have 4, JD, MF, (2) Kubotas.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
TANK MANIFOLD (A60736)
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
2014 FORD F150 4X4 PICKUP TRUCK (A59906)
2014 FORD F150 4X4...
2021 Forest River Puma PUT31QBBH Travel Trailer (A60352)
2021 Forest River...
