careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,767
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
Well I don't recall it either.Probably did Scotty, but my memory doesn't serve me to well these days.
I have 3 John Deere 850,s. 2 or 3 yrs back I took the loader off one tractor and installed it on another one. When I transfered everything the loader would not work. I had forgot to transfer the headless plug. Once I did that everything worked perfectly.I am probably not making myself clear. I still maintain if you hook things up with the headless plug and bypass you have suggested then everything will work for you. It will not be necessary to remove the plug in order for your 3 point to work.
I think I agree with Winston here. At any rate, it would be simple to test and find out. Simply install the headless plug, and then install a hose loop from the primary A to B ports as shown. Then see if the 3pt will work.I am probably not making myself clear. I still maintain if you hook things up with the headless plug and bypass you have suggested then everything will work for you. It will not be necessary to remove the plug in order for your 3 point to work.
What? Why? That doesn't make any sense. I think it makes more sense to leave the Yanmar thread where it is. Is it possible that your search has some references crossed with Int. Harvesters?I would move this thread. I ran a quick search and keep coming up IH.3444-4690
It's huge would be nice on my 63Ford !!
Be watching for it if you do just being curious. They offer a manual on it just so happen to be it!....... Don't look like much Info. though.
International Harvester 3444 backhoe-loader technical specs, dimensions, horsepower, fuel economy and equipments gasoline
International Harvester 3444 backhoe-loader technical specs, prices, sizes, fuel economy, gas mileage, PTO and drawbar equipments gasoline get your International Harvester 3444 backhoe-loader service repair manual and find your needed parts and accessorieswww.manytractors.com
