I broke it again.
/ I broke it again. #1
Tchamp
Baldwin Georgia
Power trac PT-2422
I broke the pivot arm on my 2422 again, have it apart already and waiting for the machine shop to turn down another section of round stock to replace the broken one, this time i am going to have the center bar supported with corner bracing so it will not flex as easly, distributing the pressures across the center section more evenly. Will put pics up when i am done.
I have to check the hydraulic pressures for the lift and see if they are correct. Terry told me that on the lift and steering its 2,100 psi and on the aux its 2500 psi. I am thinking that may be my issue for the failure. (Me worrking the machine to its limits has nothing to do with it at all ) lol.
/ I broke it again. #2
It never crossed our minds. That is a neat little machine.
/ I broke it again. #3
View attachment 861735View attachment 861738View attachment 861739
Ouch! Sorry to see that. Based on my own experience, trying to tackle immovable objects, the back wheel(s) come up before any noticeable relief valve action, at least on my PT.
By corner bracing, do you mean gussets? If so, I think that it is a good idea. Have you considered upgrading the outer roll tube wall thickness as well?
Since you have had this apart before, how large is the spacing between the inner bar and the outer roll tube? And out of curiosity, how do you align the outer and inner tubes when welding it up so that the spacing is uniform? (Just curious; it seems not trivial to an amateur welder like me.)
All the best,
Peter
/ I broke it again. #5
I would check the relief valve for that circuit/spool. Just get a 3 to 4k lb gauge with a -4 JIC male fitting and install it on a hose that goes to the tilt cylinder and momentarily dead head it (best with hot hyd oil).
On the repair, why not get a hardened steel pin that can go from side to side on the loader arms and bore out the Z pivot to allow the one pin to pass through the center? (Use brass bushings in the Z pivot and weld on extensions to the loader arms for through bolts to secure the hardened pin from turning).
When it breaks, where is the first point of failure? Does the pin break out of the weld in the loader arm and then break the Z pivot?
What attachment were you using when it failed?
/ I broke it again. #6
You do realize that you can buy bar stock in the required diameter you need without resorting to paying a machine shop to turn it for you I presume. McMaster Carr sells bar stock in many different diameters as alloy's as well and so does Grainger as well as Contractor Steel and Alro.
Have no idea where you are at but I keep many diameters of cold rolled bar stock on hand. Stainless as well.
Looks like those fulcrum pins are a but short on grease as well. They are obviously galled and that contributes to reduced capacity and it ovals out the holes they go through as well.
/ I broke it again. #7
...Based on my own experience, trying to tackle immovable objects, the back wheel(s) come up before any noticeable relief valve action, at least on my PT.
Same thing on my PT425. I've never had the relief kick in that I know of. The rears ALWAYS come off the ground.
I'm wondering if the 2422's weight distribution is significantly different?
Also, I think I recall many years ago some folks had that same problem on the 400 series, and I think I recall PT making a beefier rollover assembly since then.
:unsure:
/ I broke it again.
All the best,
Peter
the machinist, measured the inside diameter of the pipe and then turned down the pin to the size of the pipe inside diameter, then welded up the pipe with the pin installed see pics for refrence
The whole job cost 180 dollars. Not bad.
/ I broke it again.
All the best,
Peter
I did consider doing a larger diameter outer wall tube but decided that I don’t think it’s necessary. for one I would have to remove the tube from the middle of the two arms, and that would be more cost. I decided just to repair it and bolster the outer tube.
I had it fail over a year ago once before the same way, but when I had it rewelded, I don’t think they did a appropriate job on the outer tube,the welds were thin and broke leaving the pressure soley on the inner pin in the middle. The weld cracked about a month after I had reinstalled it and It took a year before the actual pin broke.
We just put the inner pin inside the outer tube and used it to align the two pieces then welded them back together. It is pretty close tolerances so it shoold be ( close enough for me) good enough.
I think the additional bolstering should distribute the pressures from the pivot allowing the pin to have a more evenly distribution of the pressures instead of the one small point where it failed both times before.
/ I broke it again.
I am kinda rough on this little machine it gets used and abused.
The last pic shows where i used pulleys and rope to upright my machine using the ranger side by side.
/ I broke it again. #11
Starts to look like adding a ROPS could be a good investment?
/ I broke it again. #12
Now it crossed my mind it might be breaking due to abuse. Anybody else?
/ I broke it again.
Actually, I think a ROPS system wouldn’t be good for me because when it actually rolls on its side, I actually just step off of the equipment and away from it as it falls. If I had the ROPS system, I’ll be confined into it and be trapped. Not that I’m trying to roll it over all the time but when I’m in the woods on the mountains and hit a hole in on the slope or something like that it actually will turn over on me like that. I just shut it off go get the pulleys and upright it check all my fluids and keep going.
I do try to keep them to a minimum though
/ I broke it again. #15
Maybe you need the other style low profile machine. I haven't tipped one over yet.
Good job on the repair. Remember grease every 8 hours.
/ I broke it again.
I have mine out on the mountainsides here in north east Ga and on uneven terrain. The times i have turned it over i am usually driving over a old log and the tire falls into a hole covered by leafs unseen by the operator (me) always on the down hill side. Does not happen often. But it comes with the terrain, i usually am taking my time and being careful but on occasions it happens. i’m usually on property clearing trees for people that you can’t take bobcats, or anything else down through there because of the terrain and the slope. Sometimes i can only traverse the terrain by going straight up and straight back down becuase the slope is too great to drive across.
/ I broke it again. #18
I use mine on the same type of terrain in New England. The Power trac 1430 and 1460 type are the best made for side hills and stability. I have a Ryan's rotating log grapple and pull trees on side hills with the arms raised and haven't tipped it yet, thank God!
/ I broke it again. #19
😮Wow! When you wrote
"...I am kinda rough on this little machine..."
I was kind of thinking "who owns a PT that isn't using it hard?" Dropping a PT on its side definitely qualifies as "rough" in my book. More to the point, rolling would put a great deal of torsional stress on the link on the roll over pivot.
I like what your machinist did for you, and the price is wonderful. If it breaks again, I might consider braces from the ends of the roll over bar to the outer ends of arms on the roll over bar for a little more lateral bracing.
Hopefully, you won't roll your machine again. Over the years, I have lost a couple of neighbors to tractor rolls. So, I don't take them lightly. I've dropped my 1445 wheel into unseen ground squirrel holes, and it definitely gets my adrenaline going. If you are doing lots of slope work, have you thought about getting a 425 or 1860?
All the best,
Peter
/ I broke it again.
All the best,
Peter
Is the 425 more stable? I bought this 2422 with trailer and 9 attachments for around 5,000 dollars and not sure if they would work with a bigger unit or not.i think the 2422 is bigger than the 425, i actually have the 25 hp engine which makes mine a 2425. But to go bigger means all my attachments would have to go as well.
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
2015 Bombardier Evinrude 200HP Outboard Boat Motor (A66738)
2015 Bombardier...
PALLET OF MISC WHEELS (A67714)
PALLET OF MISC...
ITS 16 Pipe Squeezer (A68842)
ITS 16 Pipe...
2014 Kobelco SK210LC Hydraulic Excavator (A66734)
2014 Kobelco...
