YM276D Remote Hydraulics
/ YM276D Remote Hydraulics #1
G.Mckenzie
YM276D
Hello,
I have Question pertaining to the YM276D I am wanting to install some hydraulic quick couplers to attach a 3 point backhoe, I know there are potentially 2 options one being cutting the high pressure line and second using the in and out ports on the hydraulic block under the seat (preferred if possible) I am just not fully sure of how to set it up using the 2nd method. I did read in the manual for it that you have to install a plug in once of the ports on the block but if you want to use the pto option after you have to remove the plug each time, is there another way around that besides cutting the steel line?
/ YM276D Remote Hydraulics #2
My Ford runs a separate pump off the crank shaft pully to run the FEL.. That leaves the PTO Untouched and working ASIS.. Been setup like that for 60Yrs.. Really easy to remove it. For the BH. I would setup another tank for the Hyd. Fluid. And the run your lines back to it. My whole loader comes off in a matter of a few bolts. This is the Dr. shaft adapter
Ford 2000 Coupler Hub, Hydraulic Pump
Coupler Hub, Hydraulic Pump - For use with Loader-Backhoe Hydraulic Pumps. Hub is 4 inches overall diameter, 4 mounting holes at 7/16 inches in diameter, smooth type, 2-3/4 inch spacing. 1-3/8 inch relief diameter, 9/16 inch depth, 10 spline, 1 inch center bore.
/ YM276D Remote Hydraulics #3
Hello,
I can help you get that done, but we need to swap some information first.
About the tractor for those don't know. The YM276D is one really nice tractor. It was one of the two "top of the line" models that Yanmar sold when they first started selling in the USA. It featured optional factory power steering and front PTO, power shift transmission, and one of the nicest loaders ever. They were produced and sold for about 5 or 10 years before Yanmar began building tractors for John Deere.
Does yours have a loader? If so, there may be options there for hydraulics.
I am not aware of any 2 point backhoes? Is that a typo? Most accessory type are 3pt.
Yanmar made a backhoe to go with the YM276D. It had a special frame that fit under the back of the tractor because a normal 3pt hoe tended to destroythe tractor's 3pt hitch arms.
Not sure what you mean by cutting the high pressure line. That would be to put a "T" into the line, right?
But that doesn't work well for open center hydraulics. All hydraulics have to be in series, not in parallel.
With a T and a selector valve, you could either work the 3pt or the backhoe but not both.
rScotty
rScotty
Yes it was a typo supposed to be 3pt. And no it does not have the front loader. Cutting the high pressure line is what most of the internet says to do and install a valve to select either backhoe or pto I am guessing. A few websites have instructions on how to do that. I just know that the 276 has a second in and out port for optional equipment but it is vague on a few parts of it. Ag states said there was a part that allowed you to get this done with out cutting the line but the link is dead ended now since they bought out hoye tractors.
Scotty, this is what he is talking about when cutting into the high pressure line. Yanmar Front Loader Install
Yes essentially, but for the backhoe instead of loader. I would rather not use that method but if it is the only option apart from having to remove the 1/4 hex plug in the in and out port on the tractor.
I attached some photos of the other method using the in and out port on the tractor but it states installing a 1/4 -16 tapered plug into one of them to block off a passage and if you want to go back and utilize your pto you have to remove that again. Which seems very problematic and not quick. So I was hoping someone with a bit more experience in that area would have another option. Maybe just using the out port alone with valve and then running the backhoe return line to the top of the transmission cover there is a return plug on the top of it near the shifter.
/ YM276D Remote Hydraulics #8
Thanks Winston. Now I see what it is, I am familiear with doing that. Yes, that method of cutting the high pressure line and putting in a selector valve is venerable. It reminds me of the way that a lot of old post WWII Ag tractors got pressure for loaders. It was real popular on Masseys, Fords, Farmalls, Deeres, & Olivers in the early 1950s. It was cheap to do - could be done by nearly anyone since those old tractors didn't run much pressure or flow anyway. A common value was 3 gpm on a farm tractor 3pt. Our old JD has the relief valve set at 1250 psi. So it is was a slow inexpensive system but sure beat the only option at the time, which was a shovel. The extra time needed to switch the selecter to go from using the loader to raising the 3pt didn't matter to farmers of that era.
The YM276D has more flow than those old tractors. It shows by my specs to have 8.24 gpm flow at 2200 psi. That should be sufficient as long as he doesn't have the optional power steering.
I've run backhoes on Yanmars in about every method. Another and nicer way to run a 3pt backhoe is to use a PTO-driven hydraulic pump and an independent reservoir mounted on the hoe. But the method you linked to will work.
Quality parts are available from several places like "surpluscenter.com". No need to use an unknown kit.
BTW, there is already a port on the YM276D for accessory flow. It does the same thing but requires a special Yanmar sleeve. I remember someone posted info on that a few years back.
Yes I posted the picture of it. But still doest really answer my question regarding the 1/4 plug it says to install in the manual and if there is another way around it. I know the pto driven pump types are easy but the backhoe I have found cheap isn't that type so that my reason into looking for options.
/ YM276D Remote Hydraulics #10
Super Easy and just run the lines to you Tractor Or mount another Reservoir. Front or rear PTO.. 27 Eng. Hp. not much LOL... How much Does the BH. weight. May not even hardly lift it. My Yanmar 2000 24Hp. and it's all it can do to lift a 650Lbs. FM. and it easily lifts the front wheels moving.
/ YM276D Remote Hydraulics #11
OK. Those pictures you posted are ones I recognize from when I used to have a full set of shop manuals. They seem very complete.
Apparently the special sleeve required on some models is not quite what is required on the YM276D, the callout says it wants a 3/? -18 NPTF headless plug (means hex key plug) to block the internal flow, and then the 1/4" that replaces the exterior plug sounds like it is simply an adapter.
So is your question that you do not know if the 3pt will still work if you tap into there for the backhoe?
I'd say it doesn't look like it will from those pictures. UNLESS, you hook it up using the IN or P plus the PB port on the backhoe control valves. That PB port is where pressure would come from for the 3pt. . Does the backhoe control valve even have a PB port? That is where you need to look. and activating most PB ports on control valves also requires that special sleeve we keep mentioning - the sleeve in the valve providing the same function as that headless plug does in the Yanmar.
And I think the backoe still needs a return line that is not shown.
/ YM276D Remote Hydraulics #12
I would say, just get a backhoe attachment with the Pto pump. It is so much easier. It also gives the ability to run your tractor at a very low rpm and put the pto in a higher gear and still operate the backhoe.
/ YM276D Remote Hydraulics #13
The YM2500 had 4 gears PTO. Never used 4th on any implements. I figured PTO. Hyd. is what it was used for ?. I always wished I had the RS1400 tiller then I would have done it. The YM2000 3rd. PTO was zooming!!! I put it back into 2nd.. It worked really good in the soft garden.
Looking through the hydraulic diagrams I have a work around. So hear me out on this.... the ym276 has the auxiliary in and out port once you use the 1/4 tapered hex plug in one port to block off flow to the second port making it the return essentially and sending the fluid down to the pto. Now once you remove the attachment you typically would have to remove the 1/4 plug and cap the ports again. Since I am wanting to install quick couplers for options I am going to set it up with 3 valves and 2 T's so I don't have to remove that 1/4 plug to return flow back through the pto all I will have to do is open the cross over valve (that I will install) and close the 2 valves to the quick disconnect....I have seen those leak before. With this set up I can easily disconnect the attachment and hook up to the bushhog or tiller and only have to open one valve to use pto.... with that said after detaching the attachment you have to open that valve so that uou don't destroy your hydraulic pump.
/ YM276D Remote Hydraulics #15
This is likely the part you speak of to keep from cutting the line. Hydraulic Pump Adapter - Pump to Flex House
You are referring to pto, are you really referring to 3 point lift? Not sure I am completely following you. Yes, that would work, however, I don't think you have to do anything extra. The 3 point would lift as normal at all times unless you stop flow completely and you don't want to do that.
/ YM276D Remote Hydraulics #18
Like Winston says, you need to re-write your "hear me out" message. I also am mystified why you keep saying "PTO" (power take off - typically 540 rpm) instead of 3pt lift and wonder if we are missing someting.
Your backhoe control valve rack will have one outlet for return flow from cylinders on the unpressurized side. It might also have a PB (power beyond) port. If it does, you can use that in coming into H so you have pressure at "a" to the next valve. Otherwise, the fluid coming into H would seem to be your return flow - which is unpressurized.
/ YM276D Remote Hydraulics #19
BTW, Winston...didn't you and I work on accessory hydraulics on a 276 at least once before? I've got an old file with this jpg in it - and also some other shots plus a portion of a workshop manual.
/ YM276D Remote Hydraulics #20
rScottyView attachment 861802
Probably did Scotty, but my memory doesn't serve me to well these days.
New/Unused ATS 40 Gallon Two Stage Air Compressor (A61166)
New/Unused ATS 40...
Tandem Axle Rear Truck Frame (A61568)
Tandem Axle Rear...
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
2024 Honda CRF 450RL, VIN:JH2PD1117RK500228 (A61166)
2024 Honda CRF...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A62130)
2008 GMC C7500...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
