Trailer Ramps
/ Trailer Ramps #1
1990F-150
Member
Sanger TX
2023 LS MT240HE. Kioti ZT. Honda Pioneer 520. Ford 8n. Ford 9n. Massey Ferguson 1080. Ford 2000
I’m currently shopping for ramps on my new trailer, and I’m wondering how long I need. Right now I’m looking at 4 foot ramps, but I’m not sure that there long enough. I will be driving a 40 horsepower tractor with a six foot mower on the trailer.
/ Trailer Ramps
It’s a dovetail, so it’s only 15 inches off the ground in the back.
/ Trailer Ramps #5
At 15 inch high over a 4ft ramp it gives you a 17.5 degree angle from the ground to the ramps at 5ft you would have 14 degrees...
is it a 3 point mower or a drive over mower ?
/ Trailer Ramps #6
I would do at least 5ft.. 6ft would be flatter, but 5ft is very common and easy to find.
/ Trailer Ramps #7
Getting a tractor on/off the trailer is where you are most at risk of a turnover. Besides being long and strong enough, you want to be sure the ramps are wide enough and can't allow the ramps to skate out from under you. My ramps have drop legs to also help with weight transfer from the ramps to the trailer bed when loading or unloading.
/ Trailer Ramps
Thanks for the help. It’s a three point mower
/ Trailer Ramps #9
you can always crank the 3 point link arm adjustment to get gain clearance at the rear of the mower ... If you give me your wheel spacing Front to rear, length from center of rear wheel to end of mower and the heights your 3 point can lift the mower I can check what length of ramp you would need.
/ Trailer Ramps #10
I made 8 ft ramps for mine and my trailer bed is about 28" high.
/ Trailer Ramps #11
I picked up a pair of used equipment ramps off of Craigslist a while ago. They are beastly heavy.
There is no need to go longer than your really need.
/ Trailer Ramps
Not exactly sure on the height that the tractor can lift the mower. Last time I had the mower connected to the tractor it was about 11 feet from the middle of the rear wheel to the end of the mower.
/ Trailer Ramps #13
what tractor ? the 8n ? I need to know the distance from the front wheel to the rear
/ Trailer Ramps
My LS Mt240. I’m on a trip right now but when I get back I can get you the measurements. I decided that I’m going to make the ramps myself, so I’m not going to limit myself to a certain sized ramp.
/ Trailer Ramps #15
At a wheel base of 121 inch (front to back) a lift height of 12 inch (guessing) and the mower would be dragging by 3.5 inch, so by cranking the tree point adjustment link you should be fine. and 4 or 5 ft ramp wont make a difference for that. the only difference would be the bottoming out but there is lots of clearance there.
/ Trailer Ramps
At a wheel base of 121 inch (front to back) a lift height of 12 inch (guessing) and the mower would be dragging by 3.5 inch, so by cranking the tree point adjustment link you should be fine. and 4 or 5 ft ramp want make a difference for that. the only difference would be the bottoming out but there is lots of clearance there.
Thanks for the help. I think I’m going to make a five foot ramp when I get back to my house.
/ Trailer Ramps #17
When I had my trailer, the ramps were trashed (used) and I bought alum ramps from these guys. Was very pleased and a heck of a lot lighter than steel! I think it might have been this one, but they have a million options:
/ Trailer Ramps #18
Aluminum ramps would be nice. I dislike carrying my steel ramps that must be over a hundred pounds each, and they add to the load. I saw some go up at an equipment auction recently, and have been kicking myself ever since for not bidding higher.
I did pick up a us\ed aluminum trailer with ramps... I haven't used it much yet since it needs some maintenance this spring before being fully ready to use.
/ Trailer Ramps #19
You can get 5ft - 7ft 6000lb aluminum ramps at just about any where, including Home Depot and Amazon.
/ Trailer Ramps #20
And don't limit yourself to ramps for a specific size tractor. Make something that will maximize the trailers usage.
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
BRUSH GUARD & RACK FOR UTV (A64276)
BRUSH GUARD & RACK...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
