Need John deere 4610 help
/ Need John deere 4610 help #1
desmetde
I was stationed overseas for 4 years, meanwhile a handy man hired to maintain my property back in the states, blew the engine in my JD 4610. When I returned home I found it completely disassembled and I'm trying to put it all back together. There are a few points I'm stuck on, as I can't find any tech data on the routing or placement of a couple things. I wish I could find a 4610 near by to look at. I'm in lincoln California. I will post a few pics of the areas in question and maybe sometime out there can offer some knowledge, thank you
/ Need John deere 4610 help #2
Same engine as you were working on a few years back? Was it up and running in the meantime?
Or maybe this problem now is a different model, being now a 4610 that the engine blew??
Thank you for your service.
Yes! same engine, I just realized the fuel tank must be installed prior to installing the brake pedal shaft assy.....ugggg
/ Need John deere 4610 help #4
Israel B Moore in the marketing business??
Tell us about your experience and business?
Welcome to TBN
/ Need John deere 4610 help #5
When I got a shop manual for my 5105 I was dismayed to find out that the engine was covered in a different manual. That one is super generic to the point of not being all that useful. The shop manual isn't all that great either. Which is a surprise as the owner's manual is pretty good.
Got her running, but has an intermittent stall issue, sometimes a very slight hiccup, other times a stall, I can hear the fuel solenoid click when this occurs
2022 EZ-GO ELITE...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2016 Crane Carrier Co. New Way 31ASL 31Yd Side Loader Garbage Truck (A61573)
2016 Crane Carrier...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
