ford 4500 backhoe
/ ford 4500 backhoe #1
m4500
ford
just got a ford 4500 diesel backhoe. wanting to change oil to start i don't know what oil they were running in it. i believe it may have been regular 10-40w conventional oil. should i stick to that or should i put in something like shell rotella or mobile delvac?
/ ford 4500 backhoe #2
Being that it is very old, anything above 30wt is spoiling it. A good quality hyd/trans oil is fine for everything else
/ ford 4500 backhoe
then should i just use 10-30w regular oil in it . tractor is in good shape for it's age dosen't use any oil.
/ ford 4500 backhoe #4
Yes, that is fine.
By the way, welcome to TBN!
Have fun with your 4500. Make sure you grease the hydraulic pump driveshaft under the radiator and the 2 zerks for the steering mechanism
/ ford 4500 backhoe
if i switch to oil rated for diesels and it has been using regular oil will it break loose any sludge and harm the engine.
/ ford 4500 backhoe #8
No, it won't
2017 Autocar Xpeditor T/A EZ-Pack 40yd. Front Loader Garbage Truck (A66736)
2017 Autocar...
2014 Kobelco SK210LC Hydraulic Excavator (A66734)
2014 Kobelco...
2017 INTERNATIONAL 4300 6X2 S/A 26FT NON CDL BOX TRUCK (A67737)
2017 INTERNATIONAL...
2012 FORD F-550 CAB AND CHASSIS (A67714)
2012 FORD F-550...
2012 PROCCO 130BBL (A67714)
2012 PROCCO 130BBL...
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
