ford 4500 backhoe
/ ford 4500 backhoe #1
m4500
ford
just got a ford 4500 diesel backhoe. wanting to change oil to start i don't know what oil they were running in it. i believe it may have been regular 10-40w conventional oil. should i stick to that or should i put in something like shell rotella or mobile delvac?
/ ford 4500 backhoe #2
Being that it is very old, anything above 30wt is spoiling it. A good quality hyd/trans oil is fine for everything else
/ ford 4500 backhoe
then should i just use 10-30w regular oil in it . tractor is in good shape for it's age dosen't use any oil.
/ ford 4500 backhoe #4
Yes, that is fine.
By the way, welcome to TBN!
Have fun with your 4500. Make sure you grease the hydraulic pump driveshaft under the radiator and the 2 zerks for the steering mechanism
/ ford 4500 backhoe
if i switch to oil rated for diesels and it has been using regular oil will it break loose any sludge and harm the engine.
/ ford 4500 backhoe #8
No, it won't
Nissan Forklift (A55973)
Nissan Forklift...
2005 DRAGON 130 BBL STEEL VACUUM TRAILER (A60736)
2005 DRAGON 130...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
