ford 4500 backhoe
/ ford 4500 backhoe #1
m4500
ford
just got a ford 4500 diesel backhoe. wanting to change oil to start i don't know what oil they were running in it. i believe it may have been regular 10-40w conventional oil. should i stick to that or should i put in something like shell rotella or mobile delvac?
/ ford 4500 backhoe #2
Being that it is very old, anything above 30wt is spoiling it. A good quality hyd/trans oil is fine for everything else
/ ford 4500 backhoe
then should i just use 10-30w regular oil in it . tractor is in good shape for it's age dosen't use any oil.
/ ford 4500 backhoe #4
Yes, that is fine.
By the way, welcome to TBN!
Have fun with your 4500. Make sure you grease the hydraulic pump driveshaft under the radiator and the 2 zerks for the steering mechanism
/ ford 4500 backhoe
if i switch to oil rated for diesels and it has been using regular oil will it break loose any sludge and harm the engine.
/ ford 4500 backhoe #8
No, it won't
1998 Freightliner MT45 Step Van Food Truck (A61573)
1998 Freightliner...
2014 MERCEDES 2500 CARGO VAN (A59911)
2014 MERCEDES 2500...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
