John Deere 1445 hydraulic float issue
/ John Deere 1445 hydraulic float issue #1
Dlowry
John Deere 1445
My 1445 has 1725 hrs and the deck will not stay float . It has a danfoss hydraulic control valve . I am not sure if or how to adjust the detent to keep the deck in float
/ John Deere 1445 hydraulic float issue #2
More than likely it is rusted up inside of of cap take it off some slide off others need to be popped off or pull spool with it has spring and detent balls in it so if you do try and take it apart wrap a rag around it just in case parts come flying out
Thanks for the info I will pull the cap do you recommend grease on the the balls
/ John Deere 1445 hydraulic float issue #4
Here is an exploded view of the valve from the J.D. Tech Manual. Don't ask me why it's upside down.
/ John Deere 1445 hydraulic float issue #5
Yes I use heavy duty assembly grease but anything will
Work to be honest use what is available I do this for a living so have access to many different Lubes
Perfect I appreciate the help the information answered all my questions
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
Kubota Snow plow with subframe
Kubota Snow plow...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
2017 FREIGHTLINER CASCADIA SLEEPER (A59906)
2017 FREIGHTLINER...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
2016 ExMark Vantage 48in Stand-On Commercial Zero Turn Mower (A59228)
2016 ExMark...
