Trailer question - skid steer
/ Trailer question - skid steer #61
I think I am going to go with a kaufman trailer. Got it down to these two:
The extra 2k of weight is about $1200 extra. I am pulling it with a 3500, so I don't think that matters. However may downgrade to a 2500 someday.
I have a bobcat T595 that weighs about 8100 lbs.
Why can't I find the empty weight on these trailers to figure out the payload?
Also, any thoughts on slightly upgraded trailer... worth the extra cost even though I don't really need it?
Thanks
I bet both of those trailers have the same axels just a heavier ply tire on the 17k. I would get the cheaper one and upgrade the tires once they wear out. But I would see how heavy it is before I bought it to see what the payload is.
The lighter one is 2 x 7,000 axles with 235/80 R16 LRE tires
The heavier is 2 x 8,000 axles with 215/75 R17.5
I've seen some chatter about tire sizes, should that come in to play in the decision here?
/ Trailer question - skid steer #63
Bet if you crawl underneath both trailers the axels have the same part#. I've seen this before. Besides that how does two 7k =15k & 2x8k=17k?
/ Trailer question - skid steer #64
I would think about being under the 26K pound number for the gross combined weight of the truck and trailer unless you have a CDL.
The 3500HD weighs around 7000 lbs, so with a 15k or 17k trailer should be no problem right? Unless I am reading that wrong
/ Trailer question - skid steer #66
My 2020 Ram 2500 CC CB with the gas 6.4 engine tips the scale empty at 7420 pounds, but I can gross 10K on the truck, so a 16K trailer puts me near or over the 26K limit.
Your 3500HD has a much higher payload, so you are going to be over the 26K limit.
/ Trailer question - skid steer #67
The trailer with the larger 17.5 wheels would be my pick.
/ Trailer question - skid steer #68
Thanks
Post #31 the 17k Kaufman trailer is the very trailer that I purchased and posted about, I don't remember the exact number but the sticker on mine says you can put 13k and some change on the deck, the 17.5 tires are something that I wouldn't buy any trailer without, I have them on my 30' gooseneck trailer as well, spend the extra money and get the upgraded package as you are still getting out of there with all the upgrades for a little over $8k, can't beat it.
/ Trailer question - skid steer #69
17.5 tires are way better. They might not be all that much better than a good set of 16 ply 16” tires but they’re way better than the crappy 16” tires that usually come on trailers.
Upon looking at this closer, I think you are right. The GVWR of my 3500HD is 11,600... so even a 15k trailer is going to put me over. Back to the drawing board, suppose I'll be looking for a 14k. Thanks for the info
/ Trailer question - skid steer #71
If you are buying the trailer new, you should be able to get it derated. Factory should happily put a smaller number on the tag to keep you legal. May be free or a cheap option.
Didn't realize this may be an option. I wonder how difficult it would be to "re-rate" it if I go to sell the trailer
/ Trailer question - skid steer #73
Depending on where you live and how the trailer is tagged makes a difference. Some allow for non-commercial drivers licenses up to and including class A (with/without endorsements). Depending on the state, a truck or trailer (or combo) is not auto magically commercial. What you are using it for determines that.
How many that claim it automagically is are paying for commercial insurance on their p/u and trailer?
/ Trailer question - skid steer #74
My trucks are on commercial. With the stipulation that I only haul cargo that I own it’s cheap. I pay more for my raggedy personal vehicle that’s worth $3500 than I do the commercial trucks.
I ended up getting a bigtex 14TL-22 (14k 22ft tilt trailer, 16+6)
First trailer outside of RV's
First thing I am going to use it for is renting some skidsteer attachments. Can anyone give me a quick primer on securing these things? Recommendations on tie downs? Use fabric tie downs for these attachments? Brush cutter, grapple, etc... around 1000 - 2000 lbs
/ Trailer question - skid steer #76
Did you get fork pockets?
/ Trailer question - skid steer #77
Ratchet straps will chafe or cut if they rub on stuff. I cut one half way through early on cranking it down on a bar stock grill guard. It wasn't even sharp, but did damage to the strap. I generally use chain & binders for all my machines & implements now.
I still use straps for other stuff or machines if I can guarantee they won't hit anything but a smooth surface or won't rub anything.
/ Trailer question - skid steer #80
From what I understand its only an option when its built & first registered. OEMs won't mess with re-rating them once they leave the factory or get sold.
METAL SAW HORSE (A68842)
METAL SAW HORSE...
2013 CHEVROLET SILVERADO 1500 (A67714)
2013 CHEVROLET...
18 FOOT WATER TANK TRAILER (A67714)
18 FOOT WATER TANK...
FOUR RACKS OF MISC FILTERS (A68842)
FOUR RACKS OF MISC...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65056)
KNOW BEFORE YOU...
2016 John Deere 250G LC Hydraulic Excavator (A66734)
2016 John Deere...
