You Know You Are Old When
/ You Know You Are Old When #1,042
My first wife had one, didn't think it was a bad car. Felt a lot more solid than the Japanese cars of the day.
Actually the Bobcat was the Mercury version of the Pinto.
I liked the early 1600cc engines but not so much later the 2000cc, 2300cc and 2800cc V6…
I much preferred my 1970 slant 6 valiant…
/ You Know You Are Old When #1,043
Wife had an 83 Cavalier with a removable sun roof. She loved it. Never leaked.
Our current 2013 Impala has a sun roof. I like it a lot. Never leaks.
/ You Know You Are Old When #1,044
Many times I fixed the sunroof leak by clearing the built in drain lines.
Water had no where to go and would build up and leak inside.
The long flexible GI medical cable perfect for the job.
The shop would spray a little silicon into the mouth of line which often prevented clogs.
/ You Know You Are Old When #1,046
I hope nobody ever tries to give me a vehicle with a sunroof.
Same here. Back in my EMT/Firefighter days I responded to a rollover accident. Pickup truck flipped over on its roof and skidded about 50 yards down the highway, sliding on its roof. The sunroof of course shattered; the driver was seatbelted in but the seat belt could not hold the driver tight enough and his head was essentially scalped. Messy!
/ You Know You Are Old When #1,047
That's reason enough :eek:
/ You Know You Are Old When #1,048
There should be enough old timers here for someone else to have experienced this variation of the 'doorway effect' which takes place when a person walks into a room and forgets why they're there.
Several times lately I've gotten close to what I went to get, forgot what it was, raised my hand, stuck out my pointer finger and found myself pointing right at it. It's almost as if my hand knew I'd forgotten and helped me out.
Has anyone else found themselves pointing at what they forgot they were looking for?
Here's the only explanation I can think of as to how it happens:
As I approach the place I left the object I start to reach for it. My brain decides I can take it from there and momentarily goes to another thought, then realizes it's forgotten what I need to pickup. My hand, which has started to reach for the object doesn't know what to do and begins a jabbing pointing motion which gets me back on track.
/ You Know You Are Old When #1,049
Just one more. It is a balanced 347 ford stroker, around 425 HP, mustang T5Z 5 speed tranny, T-bird IRS, in a 2500 pound miata.
Was it a stroked 302?
Looks like a sweet setup! Those Ford strokers made a ton of torque. My Mustang had a Dart sb
427 with about 630hp and was a torque monster!
/ You Know You Are Old When #1,051
That slant 6 was a good motor!
I would tow my home made dump trailer which it did fine except on one steep road it just was not enough to pull loaded with a yard+ dirt.
Friend had a 318 Valiant no problem.
But the 318 was thirsty compared the slant 6
/ You Know You Are Old When #1,052
You know you are old when you crank started your first car and quicky learned to park strategically on an incline whenever possible
Didn't have a crank start, but the incline came in handy when I couldn't afford a new battery. (That was pre-everything is an automatic) for you younger folks.
/ You Know You Are Old When #1,053
One like this? I've had it 50 years . I just took it out for a spin...runs great. I try keeping it original as possible, the tube radio still works. It's a 1958 and I've gotten 50 mpg...back when gas was 18c/gal.View attachment 855359View attachment 855360View attachment 855361View attachment 855362View attachment 855363View attachment 855364View attachment 855365
A good friend had one just like that in the late 60s. He drove it to LA, but I think he sold it there. His was a 59 I think.
/ You Know You Are Old When #1,054
Most guys wouldn't be caught dead driving a Met...but girls think it's so cute and want to ride in it...even with an ugly old bald grandpa driving it!
16 second clip driving down a back road today.
/ You Know You Are Old When #1,055
I drove his once. Three on the tree I think. It was 1969 when he had it. Definitely not the car for date time shenanigans though.
/ You Know You Are Old When #1,056
Wow, awesome picture, looks like a great traction monster.
Yes, it started out as a 302 for the first 6 years the V8 was in there, and then one fall I decided to buy the balanced stroker kit so I removed the 302, stripped the block bare, and had a local Ford guru in our area bore it out .030 thou, and set the new crank, pistons and cam back in it, and then I did the rest. It also has the 351 heads. I,ve never raced it, or run it on a track. The guy in San Diego that actually makes and sells kits to install the 302 engine has had his up to 150 mph on a track, but said it gets very light in the front end and was afraid he won,t be able to steer it. There is a guy that goes by the name AVANTI that bought a car that basically started out the same as my 347 stroker for his wife to run on the Bonneville salt flats, and was then heavily modified by someone in California for aerodynamics, that ran 175 mph on the flats. Much, much more brave than me. LOL
What distance and times did you run with your monster ?
/ You Know You Are Old When #1,059
You were hauling the mail 30mph!
Thanks for the clip bro!
/ You Know You Are Old When #1,060
It ran a best of 10.08 @ 132 at Famoso raceway in Bakersfield Ca. 1/4 mi.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2018 Navigator RT-6500 6,500lb Piggyback Trailer Forklift (A59228)
2018 Navigator...
