Brush cutter opinion/help
/ Brush cutter opinion/help #1
D&D
KIoti, JD, Kubota
I’ve been talking myself into a front mounted brush cutter and exploring some options. One thing I’ve noticed is a couple of the manufacturers may not be using a cushion valve on the motor, rather just teeing the lines. One side of my brain says that can’t work very well, the other side says but you’ll save ~150 bucks.
‘This is not to berate anyone else’s build, noticed on this one and the lane shark, just wondering how the T would work. This video clearly shows the arrangement at the 14:13 mark,
/ Brush cutter opinion/help #2
Yes, it's T but between both T's, there is a check valve. This check valve will allow the hydraulic motor to spin down on it's own, instead of an abrupt stop that would most likely blow the seals on the motor. It will also prevent the motor from rotating the wrong way, even though it's not usually an issue with brush cutters.
Both setups will technically do the same job, albeit in a slightly different way.
Personally, not a fan of these loader mounted brush cutters. The tractor has a perfectly good running PTO in the rear capable of delivering most power out of the engine, so I don't understand why limit it so much by going hydraulic.
About the only scenario I see this could be useful, is mowing high embankments.
In that video, what would work perfectly would be one of the chain cutters we use in this side of pond. Pretty much perfectly scenario for it.
With the check valve opening from return side, correct? Wonder why so many claim a cushion valve is the only way to stop seal blowout? GPM have an effect on which is better?
Practicality comes into play depending on how many trees/ obstacles to mow under and how much you like reversing. A boom or ditch bank mower may suffice, researching options.
Thank you.
/ Brush cutter opinion/help #4
Looks like this setup uses the 3rd function, so when you release the button, both work ports of the valve are blocked.
Basically when you turn the cutter off, the inertia will turn that motor into a pump. With the check valve, the fluid will pretty much flow between just the motor and the check valve, pretty much making a small circuit up to the Ts.
The cushion valve uses two relief valves that open to the opposite side. Once there is a pressure spike like when turning the cutter off, it relieves the pressure to the other line. Using this valve, will allow for a faster slow down of the motor without blowing the seals.
Adjusting the relief valve on the return side of the motor, adjust how fast/slow it will take to fully stop the blades.
While with the check valve, it will coast down a lot longer till it finally stops.
Either way is fine really and both ways prevent the seals from blowing out.
I have an homemade flail cutter for my backhoe done with the check valve route. No issues whatsoever.
From what I’ve been reading and seeing, the 3rd function pressure side is often used, a separate return to tank is somehow incorporated, teed before 3rd valve or direct to tank. I have a separate 25 gpm pto pump/tank combo available, was leaning towards that and just running two lines. Kinda depends on how much cutting capacity. I like the lane shark concept, beefing up to a 6” plus tree killer offset and vertical would probably require some counterweight. This setup would not be healthy for the loader arms/attach points on a compact/utility tractor.
/ Brush cutter opinion/help #6
One advantage of a hydraulic front mount brush cutter is the blades are sharp on both sides so it can rotate either direction.
Here is the new version of mine: Tree Terminator Rotary Mower
Got my 7' in 2009:
Still using it now:
The hydraulic motor has a built in cushion valve:
Got my 7' in 2009:
You and some others here are why I’ve been pondering the thought. That one, rotated 90 degrees and stuck out ~18” would be great for horse trail cleaning. How stable would it be though? And what negative effects on the qa and boom would crop up?
Right, all of the premade ones are 42-44” which would be slow going cutting up to 8 feet off the ground. On the flat, I know that small of cut would just be a waste of time and fuel. Hence the hesitation to do anything.
/ Brush cutter opinion/help #11
I have a Lane Shark, can confirm that the WR Long 3rd function hyd kit comes with a separate return line to prevent overheating the fluid. It takes a while to spin down after deactivating. There are a few videos explaining the plumbing and reasons for the design on the Lane Shark website.
My grapple is currently attached, but the green capped line is the Lane Shark return line:
My primary use has been turning it 90° and running down our trails to getting up high & trim back branches; It also does a great job of cutting back thick brush / vines working from the top down when set flat out in front.
It's definitely not the end-all-be-all tool for every job, but fits my specific needs perfectly.
Thanks Yes, that’s a big part of it, always need more than one thing to do the job. Yours works pretty well on your DK? How far does the deck sit out from the front tire at 90? maybe the answer for my desire is a lane shark type in front and a 6-7‘ flail in back
/ Brush cutter opinion/help #13
It has worked fine on my tractor; When flipped 90°, it sits out a few inches outside of the front tire. If you do a youtube video search, there are several videos out there showing it in different configurations on different tractors.
I don't have it attached at the moment to give you exact measurements, but I'll add some older pics when I had it in different configurations, if that helps.
2023 LHD 7000MB Mega Buggy - Only 35 Hours - Kohler Gas Engine - Rotating Dump (A63689)
2023 LHD 7000MB...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
60in. Work Bench (A65640)
60in. Work Bench...
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
2013 Ford F-150 Pickup Truck (A64194)
2013 Ford F-150...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
