Tooth bar vs none difference?
/ Tooth bar vs none difference? #21
I had a Bobcat 642 (32hp) with a smooth and tooth bucket. The tooth bucket was like having 20% more power and traction. I rarely used the smooth bucket. You will love it.
/ Tooth bar vs none difference? #22
The worse that happened is you bought from Vevor. It's a stolen knockoff of something designed in the US and built with child labor.
So is whatever device you used to post that message, along with all the local and remote networking equipment along the way to and from the internet, and that includes the main power grid transformers required to charge your device and power all the networking equipment. Sucks, but no way around it currently. Even if you're using solar, good luck finding a non-Chinese panel and controller.
/ Tooth bar vs none difference? #23
I had a Bobcat 643 (32hp) with a smooth and tooth bucket. The tooth bucket was like having 20% more power and traction. I rarely used the smooth bucket. You will love it.
The unexpected benefit of a tooth bar was for back dragging. It was like using a garden rake. Especially good when I had clumps of sod and roots in the dirt
/ Tooth bar vs none difference? #24
I put an EA wicked tooth bar on the LS XR 3140, The difference was night and day comparing the straight factory edge to the tooth bar.
Digging into piles or moving compacted soils is where they really shine. It seems when I spin a tire now with the tooth bar on the bucket, its full. When tire spin would happen with the factory edge, 'bout guarantee the factory edge was hung up on something and bucket not even close to full.
Another plus with a tooth bar is it adds rigidity to the bucket edge. When I installed the EA tooth bar, I found the factory edge was beginning to bend. Which after installing the tooth bar was straight again.
There is a learning curve after installing a tooth bar if you are accustomed to the passed dull factory edge. Your bucket will dig easier, fill easier with less force and angle. Try using a tooth bar with the same action as the factory edge, you might Have some surprises come up.
I really like my tooth bar. It makes moving material much more efficient.
Now i'm looking forward to it. If it works out well, I'll get one for my bobcat, it's a much meatier machine than the kubota.
/ Tooth bar vs none difference? #26
One thing to be aware of is the tooth bar gives you a bigger scoop and your tractor might not be able to lift it if the scoop is too heavy.
/ Tooth bar vs none difference? #27
I have a Rankin tooth bar. MADE IN WA STATE!! It hooks under the bucket lip. I made it a permanent installation - more or less. Rather than the bolts being pressure clamp arrangements - I drilled completely thru the bucket and bolted the bar directly to the bucket.
The teeth are the long style and DO DEFINITELY help the bucket when picking up "stuff".
/ Tooth bar vs none difference? #28
That was the other tooth bar I was looking at oosik. Only thing was back blading a smooth surface with that style would always leave lines. Rankin makes good stuff. I have there 5 foot arena harrow and it works wonders in the tree fields.
Mikester, a tooth bar will help fill the bucket faster. But for over all volume it ads to the bucket isn't much. A tooth bar will help embed a bucket farther into stuff, giving the illusion of a too full of bucket and to much material.
It arrived early! It's heavy, and pretty heavy duty. The fit is... snug. I picked 48", my bucket is 48.5" wide, and I had to get out my motivational hammer to get it into place. The gaps under the hooks have what looks like enough space that I should be able to put a 1/4" piece of flat bar under the bucket and weld it into place.
The down side is it's raining the next 2 days, then freezing.
/ Tooth bar vs none difference? #30
Looks good. I wonder if tire chains would help at all with the traction or just tear up your turf tires?
/ Tooth bar vs none difference? #31
Very nice!! Replaceable teeth looks like too. You will like it alot!
/ Tooth bar vs none difference? #32
Motivational hammer.... Love it !
I just ordered a Piranha Tooth Bar, mostly for shaving off some soil for 2 upcoming projects.
Enjoy the tooth bar!
The tires are dry rotted to hell and due for replacement, I want to replace them with R4's, but I can't find them in the right size.
The teeth are replaceable but I can't imagine them wearing out in my lifetime.
/ Tooth bar vs none difference? #34
Let us know how you like it after you've used it
I replaced the bolts it came with with grade 8 bolts of an appropriate length when the 4th one stripped just putting the nut on.
Took it out and once i figured out the proper angles, digging went great. And I hit them pretty hard, and nothing broke. My next weak point became apparent though, traction. But it dug in well and I made some decent progress.
/ Tooth bar vs none difference? #36
I’ve had one for about 8 years now and in shale country mine has but one small nick in one serrated tooth. Do grab that can of red or orange paint and paint the tips of both outboard teeth. Your body will appreciate it later as you step too quickly across the front and get too close. It also helps you avoid ramming it into things as they stick out past the bucket lip if turning in close quarters🫣
The bar itself is fantastic within its machines limitations. I like the way it sort of holds some of the old horse poo and hay that tends to fall out when I lift. Whatever this is made of it hates to rust. It’s been in cold barn weather since 2015 here in the Arctic Swamp of NewYorkistan and there is only light surface rust just starting. Strange🤔
/ Tooth bar vs none difference? #37
My whole tractor is orange and I still bust my knees or head on it.
It's a pain like no other! I tied yellow caution tape to my ssqa auger after walking into it several times.
I look forward to some grading work with the tooth bar this spring.
/ Tooth bar vs none difference? #38
have a Woods hd bar bolted on mine that i haven't removed since tractor purchase. go as heavy duty as possible. to me having one is like the difference between a round & square nosed shovel
operators probably already know FEL is not meant for excavation esp with a small sub compact your size. but do think a bar would help in your application
like the idea of back dragging as well. to me taking a speedy run to the pile is hard overall on the drive train, regards
/ Tooth bar vs none difference? #39
...............To me having one is like the difference between a round & square nosed shovel
.................like the idea of back dragging as well.
/ Tooth bar vs none difference? #40
The old style bar with long teeth work really well for hard soil. The piranha style is better for cutting and ripping roots and vegetation.
Just got my Piranha tooth bar, specifically for ripping some roots where I plan to build a shed. I asked on here about using it on roots to an 8" Maple tree stump and got answers that it wouldn't work, well we'll see soon. I'm just waiting for the frost to thaw.
MAXEY PORTAPOTTY VAC TRAILER (A67714)
MAXEY PORTAPOTTY...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
2017 Blue Bird 71 PAX School Bus (A66736)
2017 Blue Bird 71...
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
