Shop build and heating in 2024
/ Shop build and heating in 2024 #1
miscjames
Kubota L3901
I am in the planning stages of a shop build 30x40 12’ high side walls. Metal building on slab with 12x12’ door, One walkindoor and two 12”x12” window frame outs in the gables for fans. And i plan to insulate.
I live in East Tennessee and i am looking for suggestions on heating.
My first thought was to go radiant floor but foam board insulation prices suitable for under slab (20 psi or greater) is really souring this idea.
So what you got?
/ Shop build and heating in 2024 #2
That's a nice sized door.
What are the 12"x12" window frame outs with fans going to do?
How are you going to insulate the building?
My garage is about the same size as the shop you are building. So far it's just framed with a metal roof and house wrap on the exterior. My plan is to insulate the walls with R13 fiberglass, and then install metal siding for the ceiling, and blow in R60 Attic Cat insulation. I went with insulated panel doors because of the insulation. I've had Roll Up doors, but they leak too much air. I did the same thing for my parents garage and I've been amazed at how nice it is in there on the hottest or coldest days.
If I need to, I'll use a space heater to heat the area that I'm working, but for now, I'm not planning on doing anything else.
/ Shop build and heating in 2024 #3
I’m in South Carolina.. not a huge need for heat, but when u need it, U NEED IT..
I work on a bench 99.9% of the time.. so no real need to heat the whole thing..
I have an electric space heater down low for my feet and legs..
A propane DUAL HEAD heater w a pedestal fan behind it, on low, to blow the hot air where I need it..instead of going straight up..
And a round kerosene heater, not the torpedo style, with a pedestal fan behind it..
The kerosene heater will warm the whole building but down here it’s 6.00 a gallon, so it’s a bit pricey to run..
It’ll run 8 hours on a full tank easy..
BUT HEY, it beats being cold..
Propane is much much cheaper to run and a small “grill tank” will last for days..
In Tenn u get cold and snow, so u might want something more permanent..??
Northern Tool sells the ones that bolt to the ceiling and are hard wired to the electrical panel..
Or u could go on FB market place and find a business that does it for a living that has a bunch of “take out” units.. with BOTH HEAT AND AIR..(cheap) but it’ll be depending on your electric box..
Good luck
/ Shop build and heating in 2024 #4
I'm still in the planning stages for a new workshop here. I'm debating about under floor insulation and in slab PEX. I will probably go that way because I expect the shop to outlive me, and perhaps plans will change. Do it right the first time.
I want some brick in it. It will slow me down a lot, but that's what I'd like.
As far as roof insulation, I was originally interested in the fire resistance of rock wool. But I'm now learning more and more about closed cell spray foam that has excellent vapor barrier properties, and can also be reasonably fire resistant, especially when protected from oxygen exposure.
I think the spray foam can be applied directly to metal and will prevent condensation from forming at all in the back side of the metal.
I'm currently planning on wood heat. I have a fair amount of dead wood here every year, and think I can probably get a permit from the forest service to get wood out of clear cuts and slash piles.
/ Shop build and heating in 2024 #5
A few questions. Heated all the time or just kept above freezing and heated when working? Natural gas available? Electric supply?
Cheapest is probably gas furnace. Mini-splits may be a DIY option for you. For insulation, will you have a ceiling? That helps a lot on heating and makes a lot of insulation economical.
/ Shop build and heating in 2024 #6
Determine your needs.
How "perfect" does it have to be?
What are you going to do in there? Will you be laying on the floor a lot? Or just walking on it?
I've a 40Wx60Lx12H in northeast Mississippi I bought in 2010 (along w/ other bldgs, a house and 73 acres). Gets cold in winter, warm in summer, only has a little insulation under the steel roof. But the climate and I sort of get along. I've a 20x12 section w/ A/C and beyond ducking in there on occasion during extreme heat it's rarely needed by me. I've a small salamander heater I've used on occasion in the winters (avg low in Jan 32 deg F).
But I'm from Vermont and to me it doesn't get REAL unworkable cold until water freezes inside, then I get out my pet salamander.
But it's mostly vehicle and "stuff" storage.
/ Shop build and heating in 2024 #7
A couple good points. Is this shop something that will be used 'most every day in cold weather or only occasionally? If the latter, a woodstove might suffice.
Given that you're in the south, it would seem to me that A/C is at least as important as heat, if not more so. That would give an edge to mini-splits. Your winters are mild enough that a heat pump system might be the best solution, and would probably handle what's considered cold weather there.
/ Shop build and heating in 2024 #8
Live in the NW it gets cold here in winters. My shop is 60x40 with half being insulated and having 2 big 12 high doors so sealing them off from the cold is difficult. I installed foam pieced on the inside door panels, also installed a secondary ceiling that is insulated above ,with 12 inch batts, just high enough so to back my dump truck in when needed. Their are three heaters all electric that warms the back section being 24x12 with a stud wall and 8ft sliding door in the middle. I can shut this space off from the front section as this is my lathe, Mill and drill press area that I heat all the time. The second heater out front where my tractors are kept I use an 1000-5000w selectable electric heater that I mounted on a wood dolly so I can move it around, it uses a long piece of 10 gauge SO cord running on 230V and the heater has a good fan drive to blow heat where I need it when working on my equipment. I put power on both side walls to plug the heater into but dont use this hearter a lot, just when it gets to cold for me, about 35-40 these days. This area stays pretty warm being well insulated and with 51/2 inch concrete slab. I also have and use, two big rubber floor matts, the ones used for horse stalls that help keep my feet warmer when around the tractors and such. I just move them where needed and they are great for both walking and knealing when changing tires, oil etc.The last 12x40 section is also walled up and insulated and where I keep all my nand and power tools. It has a 8ft ceiling and is heated via a small electric wall heater with T-stat that keeps the room at 65 all the time same as the lathe room. Above this room is storage for all my junk but for many years was the hay loaf when our girls had horses. Both my Sons grew up in this shop learning lots about machinery, running the lathe, air tools, welding and such and now they are all grown have their own shops and heavy equipment repairing whatever needs it! While many dont need a shop like this one, I felt it justified for my needs and hobbies and it has turned out to work well for my needs.
/ Shop build and heating in 2024 #10
photo credit Ed Fensholt Sr.
Im planning a 64x40 shop/home in Colorado at 9000ft. No need for AC, just open some windows. Its a high wind area, buildings need to be rated for 130mph wind. Im probably going to use 14ft off the 64' length for living space on the west end, the side facing the 14k high peaks of the Sangres. That should give me 560 sqft of living space, which for me is plenty. The balance of approximately 1960 sq ft will be shop space. Im hoping to build airplane engines from automotive engines. Huge demand in the <80hp segment since Rotax killed off their 2 stroke engines. I will have a car hoist and 12' ceilings. I am planning radiant heat for the slab. There is basically no way one is going to heat a concrete slab using air, especially if it was not insulated in the first place. It will be zoned so that one has the ability to lower some inactive zones compared to active ones but the mass of the slab will be slow to react so one cant expect to be turning the heat up and down on a daily basis. The radiant heat should make working on the floor under a vehicle a lot more pleasant than the past 20 years either roasting on asphalt in summer, while being bitten simultaneously by 20 mosquitos, or shivering while lying in a puddle or fresh snow the other half of the year....
Im going to have a separate dirt floor 2 container barn consisting of 2x 40ft high cube containers spaced 32ft apart and with lean to roofs over the containers and an additional 12ft on the south side for an area with solar gain (probably double wall polycarbonate panels to let through sunlight on the south side). The open area in between will have 32ft wide scissor trusses raised up about 3ft above the 9'6" of the containers. Pier footings for the containers with 1/2" steel plate on top for welding the containers onto. Im not going to be relying on weight alone to stop the containers moving.
The container barn will provide all the space I need to park my equipment out of the weather and out of sight and give me space to store building material out of the weather (in 2 containers and lean to) as I get ready to build the main residence. The building season is pretty short and I dont yet know the turnaround time with the county for permits and I do know that any trades people will be busy as hell all summer building multi million $ mansions for well heeled folks up on the ridges. Mostly summer cabins at that too... I believe that asking rate for builders is well north of $400/sqft so Im going to have to do just about everything myself. The concrete pour and finishing of the main slab is my biggest headache. If I have no alternatives I may just have to do it in multiple pours 40' wide x whatever dimension is needed to accept 10 yards since the concrete is already $211 per yard without partial load fees..... I have reached out to a few concrete contractors for labor to handle the pour and finishing, so far have not had anyone bite. I was going to do all site prep, vapor barrier, insulation, rebar, formwork myself and just ask for help with the pour itself. If the contractor comes to inspect the site the day prior they can get any issues addressed prior to the concrete showing up. But so far that plan has not yet borne any fruit.
/ Shop build and heating in 2024 #11
FYI Home Depot has 2" R-Tech foil faced insulation, rated for under slab use. For my 40'x64' slab it says I will need 88 units for $1851. The Owens Corning Foamular 250 is more expensive at $4704. Their price has gone way up for sure.
/ Shop build and heating in 2024 #12
Floor heat is absolutely wonderful, I think.
Like westcliffe01 I thankfully don't need A/C. But I do have two 14' tall doors, the other three are 12 footers.
Already screwed up once (my garage in SoCal) and thought "I'll never need more height than that". Well, I did.
Pull the heat and exhaust off the top of the roof and I plan on running a dehumidifier as well to cut down on moisture and the fans will help that process.
Probably the 10psi foam board with foil face
Good luck
My primary goal is to keep the shop above freezing. Then a nice to work in secondary.
Surprisingly the pex is not that $ you can get a 1200’ roll of 1/2 oxegen barrier off amazon for like 400$ its that underslab insulation that is $$$
think the spray foam can be applied directly to metal - most metal building manufacturers will void their warranty if you use spray foam. At least is what i have saw so far.
Yes this would be ideal
Natural gas available? No
Electric supply? Yes i plan on splitting off the house.
No ceiling
/ Shop build and heating in 2024 #17
My property is off grid, so the only electric I will have is solar PV and I have a diesel generator which I will be recovering heat off the coolant and exhaust to get the most $ per gal of fuel consumed. So having an insulated storage vessel for the hot water will help with the radiant heat. I have not yet decided on the primary heat source yet. I dont think I am going to do an outdoor boiler. Despite the amount of National forest and BLM land I still dont know how it works getting beetle kill wood off the slopes. I know they have a lot of rules banning motorized vehicles and power tools like gas powered chain saws, so I am going to have to see how firewood is brought off the mountain before I make any commitment to heating with wood. Its mostly softwood too, so thats another hurdle. Lots of volatile resin and very little in coals.
During construction I have 2 different passive vaporizing diesel heaters from the military, they dont need any power source or electricity. Fuel is gravity fed via an elevated jerry can. The small one is 9-12k btu. The larger unit will produce 20-60k btu with the same operating principle. Both are modern with an efficiency of about 72%. Obviously some sort of water heater would be the primary heat source. For now I am leaning towards a Rinnai Tankless water heater, the RU 130i which is a high efficiency tankless heater with a built in circulation pump. It only draws 38W when running and 1.3W in standby. It is also rated for altitude to over 10kft so my 9000ft is covered. The shop will have 2x6 walls with rockwool insulation and R60 over the attic and only 1 large door which will have 3" of foam insulation and the means to be latched against its jam reducing air leakage. I will be making the door myself and its balance system. The biggest electrical consumer will be the radiant system circulation pumps and I will get ones with DC motors so that they can run directly off battery power thus avoiding inverter losses. Once operational the radiant heat system will probably have its own dedicated 48V lithium battery system and solar panels and charge controller because the heating system is probably going to run most of the year. The generator will be on an auto start system should any of the batteries reach a predetermined voltage point.
Hunter arctic heater 9-12k btu
95-96% efficient tankless hot water heater.
/ Shop build and heating in 2024 #18
I've worked in a lot of attics, and some of them have added fans to push the heat out of the attic. They paid a lot of money for those fans because they thought their attic space would be cooler, and that would it easier to keep the house cooler and save them money running their AC units. It doesn't work. It moves air, and air flow dries out an attic from condensation that's formed in the mornings from humidity, but just moving air around in a very hot space as zero impact on temperatures.
In your case, I think the same thing will happen, or it might be worse because you are trying to condition a space, but also dealing with 12"x12" openings that will allow heat to enter the building in Summer and leave the building in Winter. The biggest enemy in keeping the temperature of a room where you want it is air coming in and out of the building. The more airtight the building, the easier it is to keep the temperature where you want it. Windows and doors make this harder. Extra windows make it even more challenging.
Then there is the lack of R-Value for every window and door. R13 Walls with 2x4 framing, or R19 with 2x6 framing is easy to maintain with good ceiling insulation of R40 to R60, but every window is going to lower your R-Value because they are in the R2 to R3 range. Doors can be better, or worse, but not by much either way.
The better your insulation, and the better you control the air flow, the easier it is to heat or cool a space.
/ Shop build and heating in 2024 #19
Not sure why ventilating an attic doesn't work. When the sun heats a roof (especially a dark colored one) the attic gets much hotter than the outside air. Ventilation will bring it back down to near outside air temperatures. In one house I had a garage (no ceiling, no roof vents) that would get very warm in the summer. I added a non-powered, wind powered type of ventilator and soffit vents and it didn't get hot anymore. In the winter I would block the ventilator to keep it from getting so cold.
/ Shop build and heating in 2024 #20
No ceiling
I dropped a 400 amp service in the yard and split 200 to the house and 200 to the shop. The single meter let me dodge the charge for a separate service.
(INOP) 2016 FORD EXPLORER 4DR (A59823)
(INOP) 2016 FORD...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bestway Ag 30 Gallon 12V UTV Skid Sprayer (A60463)
Bestway Ag 30...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
