Correct use of shuttle shifter
/ Correct use of shuttle shifter #1
steve2
alum creek, wv
kubota m7040
Have a 2013 M7040SUHD with shuttle shift lever on steering column. I clutch every time I move lever between forward and reverse. Working with friend today operating a compact tractor with forward and reverse pedals no clutch action applied when stepping on forward and reverse pedals. OM for my tractor doesn’t address the question. Have I been stomping a redundant extra step every time I go between forward and reverse for ten years or properly operating the shuttle shift?
/ Correct use of shuttle shifter #3
Well for fwd reverse anyway still need to clutch to shift gears 😉
/ Correct use of shuttle shifter #4
Depressing foot pedal on M7040 with hyd shuttle only opens a hyd valve. Loading/unloading rd bales with my M7040 hyd shuttle I utilize foot accelerator pedal so engine lowers to idle speed when changing directions without depressing clutch pedal. Only utilize clutch pedal for changing standard gear box & hi-lo gears
/ Correct use of shuttle shifter #5
Though one need not use the clutch when changing directions with your hydraulic shuttle transmission, is is good practice to do so.
Sounds like friend's tractor is a hydrostat, a completely different animal.
/ Correct use of shuttle shifter #6
Operated shuttle shift tractors alot - no clutching is needed unless changing gears.
Even then some of these tractors had a 4 spd tranny and no clutch
/ Correct use of shuttle shifter #7
My '11 Kubota M7040 operators manual clearly states on page 22 that to shift hyd hi-lo doesn't require use of clutch pedal! My M7040 has had direction of travel changed many 100's times in the 1800 hrs of use handling rd bales.
/ Correct use of shuttle shifter #8
Hydraulic shuttle no need to clutch.
Manual shuttle or most synchronized shuttles you do need to clutch to forward/reverse
/ Correct use of shuttle shifter #9
As I stated, not needed but good practice.
  • Good Post
Reactions: JWR
/ Correct use of shuttle shifter #10
Have hydraulic shuttle no clutch forward, reverse I do use clutch when changing gears, engaging pto, it's an old l 4150 and imo best of both worlds. My 2850 has manual shuttle, clutch required F/R if only my 4150 had a loader id consider fixing the few non detrimental quirks it has. In any case a hydraulic shuttle sold me and is what I'll always be interested in from now on.
2022 Case SV280 (A60462)
2022 Case SV280...
iDrive TDS-2010H...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
