EdGooding
Gold Member
- Joined
- Sep 12, 2016
- Messages
- 318
- Location
- Montpelier, VA
- Tractor
- 2006 Massey-Ferguson MF-1533, 1973 Ford 3000, 1952 Ford 8N
4500 foot capacityGo big or go home, baby!!
Are you sure about that? WARN themselves say that the PW's winch is basically an M12000 with a reversed direction and low-voltage cutoff, and the M12000 maxes out at 440A draw (still way too much for a tractor, but then he's probably not talking about a 12K winch, either).
Completely forgot I posted this question. It's a Harbor Freight 12,000 lb APEX with synthetic rope.I think it'd be most helpful to know what the winch would be used for, and how often.
About two years ago I installed an 18K winch on one of the Unimogs, one of maybe two dozen winches I've added to various vehicles, basically to be able to upright a tractor if needed.
That was the most complicated mount to make to date, due to very little space to work with, but being able to pull the skid steer out a couple of times made it well worth it.
I'm not certain what battery I have on the tractor. It's a Kiot DK6010. I'll have to check next time I get over to the property it is on.Electrical power would be the biggest concern. If you look at the alternators on most <60HP tractors, they are like 45-60A. The battery is often <600CCA. There's not many good places to mount a second battery. If you insist on doing this, get a high quality deep cycle AGM battery. Some tractor companies offer an optional upgrade alternator - Kubota has a 130A, for example.
Hmm. Never thought of that. Problem is I already sunk the money into this one. I guess I could potentially resell it but it's brand new so I am sure I would lose money on the deal.Keep an eye open with some of the local farm auctions. Or, even tractor and dozer wrecking yards.
A small hydraulic winch might be very nice for a tractor.
I am. Harbor Freight Apex 12,000 lbAre you sure about that? WARN themselves say that the PW's winch is basically an M12000 with a reversed direction and low-voltage cutoff, and the M12000 maxes out at 440A draw (still way too much for a tractor, but then he's probably not talking about a 12K winch, either).
I actually didn't Good catch. What is the significance of that?Did you notice the crack in the lower left of that plate?
