TYM T25 this thing is amazing!!!
   / TYM T25 this thing is amazing!!! #61
Like dealing with it without an open station tractor?
Not everyone is willing to toss money around for a 2nd tractor or the cab cost just for convenience.
Has nothing to do with convenience at all and everything to do with the constantly floating chaff the round bailer produces. Besides, nice to work in a climate controlled atmosphere in comfort. I don't do the snow thing anymore, one of my renters has a truck mounted plow and he clears the drives.
Besides, paid for a long time ago.
   / TYM T25 this thing is amazing!!! #62
The heated and A/C cab on my LS 4140 was a $4k upgrade on a $27k tractor. Not too bad. I thought I needed it more for snowblowing. But it is nice to have the A/C in the summer and a cab to fend off the dust and insects.
I looked at it as a 20 year investment and $200/yr seemed worthwhile at the time.
The PITA part with a cab is when doing work that requires getting on and off the tractor. And they are not great for working around trees.
I am on this thread because I am looking at getting a TYM 2515. I don't think it will quite big enough to carry 1600 lbs on forks on the FEL but will be testing that at the dealer. It will be an open station and I prefer that for the bulk of work I do now...firewood processing. I bought a truck with a dump bed and plow so no longer need a tractor for snow removal.
   / TYM T25 this thing is amazing!!! #63
I guess I know a lot of real farmers back home where it gets sub zero a lot. They have cabs, but many still use open station for winter. Cabs fog up and frost over when it gets super cold. Visibility is already limited by the cab. Add in the blowing snow and many find it better to just dress for the weather and use an open station.
Not saying no one should get a cab. Just not a fan of people ignorantly assuming a cab is always best. Even in winter.
The 2515 can lift 2200 to max height and weighs almost 3000 lbs. For typical use, it will handle 1600 lbs pretty well. I would load tires and have something on the 3pt, but that applies to most FEL situations, to me.
   / TYM T25 this thing is amazing!!! #64
For a long time I only had one tractor and it was a cabin unit. Only reason why I bought a second one was, I got a heck of a deal on it, that and it eliminated me switching heavy implements all the time. My OS usually has the rake attached to it or the shredder. The cabin unit also has the computer interface for the new bailer in it, which is a PITA to change out. I'd buy a 3rd one but my wife is against that.
But your comment was about snow in an open station. Cab makes more sense baling than with snow. It depends on how cold you get. If It gets too cold, the cab makes it hard to see. Southern Michigan is warm compared to where I grew up.
Point is, no need to poke at someone who doesn't make the same choices as you. The T25 is about as nice a sub-compact as you'll find. A cab is an option, but no A/C due to only a 25 HP engine.
   / TYM T25 this thing is amazing!!! #65
Lift capacity of 2200 lbs may be at the pins. It may not handle a pallet with 1600 lbs on it.
   / TYM T25 this thing is amazing!!! #66
Had I bought a cabbed tractor and I couldn't the tractor for 3/4 of the tasks I do. Nor fit in places I fit mine currently.
Heck, I can't even use a tractor with rear mounted ROPS, let alone a cab.
   / TYM T25 this thing is amazing!!! #67
We have chainsaws to handle pesky little trees...LOL
   / TYM T25 this thing is amazing!!! #68
I have those too but these are orchards that I maintain and it's kinda counterproductive cutting the trees 😅
Although we've trimmed those a bunch so we could at least fit the tractor under.
   / TYM T25 this thing is amazing!!! #69
Figured that might be the case...just yanking your chain...no not the chain on the saw...LOL.
I hate using my machine around trees.
   / TYM T25 this thing is amazing!!! #70
I stopped and laid eyes on a TYM for the first time. Very sharp looking machines.
Snow and cold don't bother me so it's no big deal. Besides if this thing was any taller it wouldn't fit in the garage. It barely fits now with half of the ROPE bar being down
   / TYM T25 this thing is amazing!!! #72
In my case the inconvenience of having a cab far outweighs the negatives like around tree branches and far as parking it inside, the door on the big barn is 14 feet high so clearance is a non issue. heck, I park my semi and grain trailer inside it as well.
Got a kick out of the snarky comment about having multiple tractors. For me, having more than one is about convenience and I'd buy at least one more if my wife would allow it. At my age, hooking up heavy implements with multiple hydraulic hookups is a chore I prefer not to do frequently and I might add the cab tractor insulates me from spray residue when I'm spraying the hayfields for pests too. I actually change out the standard pleated paper cab filter for a spray eliminating activated charcoal filter. I don't want to breathe that stuff ever if I can help it.
I would love to have AC but this little compact has limitations. But I would much rather deal without it than worry about that dreaded word regen like these newer class of tractors have with higher HP ratings. IMO. And if given the choice between hot or cold I choose cold every time.
   / TYM T25 this thing is amazing!!! #74
Regen is not a deal killer unless you want it to be.
   / TYM T25 this thing is amazing!!! #75
Said before and will again, like Shooter Don posted, Regen is NOT a deal breaker unless you have a reading comprehension issue and cannot read the very specific instructions clearly laid out in every owners manual that comes with every new unit.
Working at the local Kubota dealer part time, I see that lack of reading and following procedures plainly stated in those owners manuals to be the primary cause of equipment failures on ECM/Emission compliant units and I will tell you that presently, Kubota will not cover the parts replacement cost for an owners negligence. They might negotiate a partial coverage, maybe, but that is a crapshoot as well.
Just had a M151 come in where the owner ignored the regen so long, it ate the head up internally as well as the DPF cannister and some DEF injection components and Kubota denied it all. M151's aren't cheap units by a long shot.
I mentioned to the Kubota rep that Kubota should eliminate the regen over ride button entirely.
   / TYM T25 this thing is amazing!!! #76
The nice thing about the TYM models with the TYM (kukje) engine is that the DPF sensor is not going to stop the tractor from functioning. No 'limping'.
If you run your tractor at the recommended RPM, most will never go into 'regen' per se as the heat is high enough to do the job while you work.
There are certainly good reasons to have a subcompact, but avoiding regen shouldn't be one anymore.
   / TYM T25 this thing is amazing!!! #77
Has anyone used the T25 with a cutter or finish mower going up/down fairly steep hills? How does it perform and what size cutter/mower did you use?
   / TYM T25 this thing is amazing!!! #78
I wear hearing protection on the tractor, so speakers would be moot. I remember chopping forage with the old German diesel 826, with the radio blaring in my face as a kid. Today I use ANR and listen to music when working. If I really want to hear the machine, I'll switch the earbuds to passive NR and listen. I've begun to value my hearing.
Hey Cloverhill, hope you don't mind me asking but what is ANR?
   / TYM T25 this thing is amazing!!! #80
Can you tell me how to connect the speakers? I have had my tractor fir about 2 months and love everything about it. But I have not been able to figure out how to pair the speakers, and the manual does not provide any information.
Shortems, what's the noise level like in the cab? Can you talk on the phone? Appreciate any insight you can give.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2022 CATERPILLAR D6XE LGP HIGH TRACK CRAWLER DOZER (A60429)
2022 CATERPILLAR...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
