   / Share Pics of People Hauling or Towing Something Wrong #19,742
I can’t believe the lengths people will go through to avoid paying the store delivery fee. Or sign up for the store pro card with no strings attached and get free delivery.
Those look like they're aluminum gutters as well so there will likely be some paint damage to the truck too . This kind of thing amazes me.
   / Share Pics of People Hauling or Towing Something Wrong #19,743
A good idea. The 7-lug was used on the HDPP option with F-250-like maximum loads. 6 lug wheels (the lugs were good enough) were not rated for those loads so by using a 7 lug wheel they kept idiots from mounting wheels too weak to carry the load.
Using a readily available 8-lug wheel would've accomplished the same thing, for a lot less money, and resulted in far less frustration.
   / Share Pics of People Hauling or Towing Something Wrong #19,745
It's a bad idea to strap cheap gutters to probably a $1200 electric side mirror, especially when you're already in a truck.
I believe the trouble is the stupid ghetto tonneau cover. I can understand the desire to have a locking cover for some occasions, but never understood those huge 1-piece hinged jobs, which make the bed totally useless for cargo.
   / Share Pics of People Hauling or Towing Something Wrong #19,747
But that would blur the distinction between an F-150 and F-250.
   / Share Pics of People Hauling or Towing Something Wrong #19,748
Gm made a 1500HD that was basically a 2500 derated to beat state rules and it used regular 8 lug 2500 wheels.
   / Share Pics of People Hauling or Towing Something Wrong #19,749
And used wheels readily available rather than $1,400 from OEM parts.
   / Share Pics of People Hauling or Towing Something Wrong #19,751
A lot of people that have them don't know what a Heavy Half is.
   / Share Pics of People Hauling or Towing Something Wrong #19,755
   / Share Pics of People Hauling or Towing Something Wrong #19,757
Wow, that's crazy!
   / Share Pics of People Hauling or Towing Something Wrong #19,758
It does appear that it might be a grade 5 or grade 8 bolt at least!
   / Share Pics of People Hauling or Towing Something Wrong #19,760
Also, the bolt appears to be undersized since they had to use a large washer on top, can you see that bolt shearing at 70 miles an hour?
CATERPILLAR OFF ROAD WATER TRUCK (A60429)
CATERPILLAR OFF...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
