   / Share Pics of People Hauling or Towing Something Wrong #19,721
I can't remember when the last time was that I changed a tire on the side of the road and I drive a lot worse roads at a lot higher speeds than most do. I did change a slow leak in my door yard two summers ago. About the time I have a flat it's usually because I need new tires.
Edit; I changed one last summer after picking up something in the road.
The rarely maintained gravel roads here in the Ozarks take their toll. 10 ply tires help a lot but even they are not immune. Sharp rocks, potholes and debris all work against your tires. Favorite so far was a rail road spike through the tread and out of the sidewall, second place goes to the spark plug my daughter found.
Have a few customers every year with on-road tires (4 ply) and flats after going to one of the creeks.
   / Share Pics of People Hauling or Towing Something Wrong #19,722
I really can't, either. And if I did get a flat tire I'd use the plug kit before switching to the spare.
Still, replacing a tire and wheel is still fully doable just like it used to be.
By the way, whats your average speed?
It depends on road conditions. Public roads I follow the speed limit +5, private gravel roads it's just as fast as I can hang on.
   / Share Pics of People Hauling or Towing Something Wrong #19,723
Public roads I follow the speed limit +5...
I don't think that qualifies as "faster than most".
Around here you'd be passed by most everybody. Someone going only 10 over would be highly suspected of being drunk, not having a licence, or involved in transporting drugs.
  • Good Post
Reactions: JJT
   / Share Pics of People Hauling or Towing Something Wrong #19,724
Yeah, the better idea people that brought us 7-lug wheels.
A good idea. The 7-lug was used on the HDPP option with F-250-like maximum loads. 6 lug wheels (the lugs were good enough) were not rated for those loads so by using a 7 lug wheel they kept idiots from mounting wheels too weak to carry the load.
   / Share Pics of People Hauling or Towing Something Wrong #19,725
I was looking at a Hundai Tucson Hybrid, and realized there's no space for a spare tire. There's only an optional goop/plug/air pump kit. I think this is the case for many modern hybrids and EV's.
I think its warranty includes road service. But I doubt anyone would come out 20 miles beyond the end of the pavement and 50 miles beyond the last gas station. Where there's no cell signal to call AAA anyway.
Looks like I'll keep the 99 Outback a few more years. And it did thoroughly destroy a tire from road debris on the freeway a few years ago. Good thing I had a spare. I can't imagine relying on just luck.
   / Share Pics of People Hauling or Towing Something Wrong #19,726
... appliances, the old ones lasted forever. But on the flip side, few want to keep a 40 year old range or refrigerator, when features and styles change more quickly than that. I'd be happy with a 20 year Fridge though, I've gotten 2 - 6 years each, out of the last three kitchen refrigerators.
Water heater in this 1943 house in town looks old, it doesn't have the usual over-pressure safety valve on top. (Anybody know how old that would make it?) It looked old when we bought the house in 1978. It works fine. I replaced the thermocouple once, no other issues.
   / Share Pics of People Hauling or Towing Something Wrong #19,727
That's odd. Not that there's not a second port for overpressure valve, but that the installer didn't tee one into the output line. I believe that's how those were usually installed, even back in the 1940's. Heck, it's how my boiler is installed today, with the blow-off teed into the common return, between circulator pumps and boiler.
   / Share Pics of People Hauling or Towing Something Wrong #19,728
I have a 150 with the HDPP package with 2592 CCC. Exceeds some 250’s.
   / Share Pics of People Hauling or Towing Something Wrong #19,729
You missed " a lot worse roads". Nobody tries to pass on the roads I drive
   / Share Pics of People Hauling or Towing Something Wrong #19,733
Good way to scratch up your truck finish
   / Share Pics of People Hauling or Towing Something Wrong #19,734
Blue painters' tape must have extra strength when installed in a girlish way.
   / Share Pics of People Hauling or Towing Something Wrong #19,735
Blow the pics up, i’m pretty sure the blue straps
   / Share Pics of People Hauling or Towing Something Wrong #19,736
Oil changes every 3000 miles, although at one time they recommended you only change the oil filter every other time.
If you had an oil filter!
'56 SBC was the first to have a filter mounting flange on the block, the '55 265 didn't. A filter canister bolted on somewhere was an option.
I recall Dad's '49 Chev used a roll of toilet paper in its filter canister, real Old School. J.C. Whitney specialized in aftermarket options like that. Are they still around?
   / Share Pics of People Hauling or Towing Something Wrong #19,738
I first thought it was painters tape until I saw a hook.
I first thought it was painter's tape until somebody said to blow the pic up and look closer.
   / Share Pics of People Hauling or Towing Something Wrong #19,739
It's a bad idea to strap cheap gutters to probably a $1200 electric side mirror, especially when you're already in a truck.
   / Share Pics of People Hauling or Towing Something Wrong #19,740
I can’t believe the lengths people will go through to avoid paying the store delivery fee. Or sign up for the store pro card with no strings attached and get free delivery.
JCB 2145 (A47477)
JCB 2145 (A47477)
TANK MANIFOLD (A55745)
2018 Ford F-350 (A55973)
2018 Ford F-350...
4021 (A59228)
4021 (A59228)
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
