how to best prepare garden from grass covered sod and weed seeds
/ how to best prepare garden from grass covered sod and weed seeds #21
You can have the best grass field, weed free and the very minute you break that ground you have unleashed weed seeds that that have layed dormant since the last time that piece of ground was broke 25, 35, 40 years ago, etc, and everytime you break it in the future. Large scale row crop farming operations have to use chemicals and pesticides but for your application with a small garden I like the black plastic idea with a drip system for watering, good luck.
/ how to best prepare garden from grass covered sod and weed seeds #22
You could try using the metal tanks form TS and set them
on the cement blocks a lot quicker and not so hard on the
back plus its a lot faster to do:unsure:
willy
I know a guy who does bag gardening. He buys bags of fertilized potting soil, throws them on the ground , pokes drainage holes on the bottom and cuts out hole on top to plant shallow rooted veggies like peppers and greens.
/ how to best prepare garden from grass covered sod and weed seeds #23
Right! DO NOT DISTURB the top two inches of soil lest the weed seeds find air and light. COVER IT ALL OVER with MULCH! Organic sheeting (card board) works also!
/ how to best prepare garden from grass covered sod and weed seeds #24
Raised beds make no sense to me at all. It's a matter of time till the weeds discover the "elevation", then you are back to square one. And the soil you put IN the raised beds is the entire picture. GIGO!
/ how to best prepare garden from grass covered sod and weed seeds #25
As others said black plastic is your friend for a seed free bed. You are going to have to break up the soil with your tiller first and essentially get all your soil prep done before apply the plastic. You will then have to wait about 2-3 weeks before removing the plastic.
Preferably do this right after a rain because you want the weeds to germinate and then have them die out from lack of sunlight. Weed seeds are all throughout the strata of the topsoil but you focusing on the ones in what they call the goldilocks zone. Not too shallow/not too deep to germinate to kill off.
If you end up tilling the next year you have to do the whole process over again because you will have reintroduced seeds to this zone.
Like KennyG said, lay out some black plastic and let it cook the soil for a couple of months.
Then I'd do some "strip" tillage, flip the plastic back with the white side up, cut slots or holes and plant through it.
KG, how does watering the soil work? We also receive frequent "gusty days w 25-30mph winds and that wreaks havoc on keeping down the plastic or anything similar.
/ how to best prepare garden from grass covered sod and weed seeds #27
Raised beds have completely changed our success in gardening. It allows us to have good dirt instead of red clay to grow our plants. Red clay turns to concrete when it gets hot outside, it's very hard to pull weeds out of red clay when it's hot outside, no matter how much you water it. The dirt that we buy remains workable until the garden is done in Summer. Weeds are easy to deal with. The other issue is maintaining the walkways around the garden. We put plastic down and red mulch over it, so the weeds that do come up are just growing in the mulch. Those weeds are super easy to pull, or spot spray with roundup.
On the lighter side (not really, this is a dead serious issue)
Introduce Asian Jumping Worms to the garden spot. They will "consume" the top three inches of organic rich soil and leave crumbly castings that allow weeds to be pulled with just a tug of the fingers.
Ask me how I know this.
Never heard of asian jumping worms, but everything from this region when it gets here, becomes invasive, except for spring rolls...
/ how to best prepare garden from grass covered sod and weed seeds #29
all plastic does is harbor bugs/worms under it and the ground gets/stays slimy cause air/light cant get under it! -- Its the WORST stuff on planet earth for gardens! It kills the soil!
ONLY way to keep weeds out is a good pre-emerge herbicide early and a LOT of hand weeding during growing season.
I do 4.5 acre garden here every year and to cultivate between rows I use TB Horse tillers til rows close in then I use the little TB Tuffy tiller the rest of the season.
Please realize this was (hopefully) a facetious comment. They also destroy the soil, and supposedly are almost impossible to get rid off.
I would first run the tiller across the garden spot, going down about 4 inches. Then have your daughters rake the sod off and put it into the compost pile.
You can also use the plastic mentioned about to plant on. Not only will it keep the weeds away but it warms the soil sooner in the spring. You also can get a porous fabric mulch. This fall I spread sawdust in the rows between my strawberries. I realize it will affect the pH and nutrient composition but I can address that when I have to.
Thanks...just spread some cottonseed meal on that sawdust and it turns the organic material into slow-releasing Nitrogen..
/ how to best prepare garden from grass covered sod and weed seeds #31
I’m thinking that if you were willing to accept a fallow year, you could periodically till then water to germinate weed seeds, then till again. Repeat throughout the growing season. This would substantially reduce the soil seedbank of weeds.
"ONLY way to keep weeds out is a good pre-emerge herbicide early..."
Sonny, what type of pre emergent herbicide do you use for vegetable gardening?
When you state "early", what does that mean in relation to your timing on planting or similar? Time planting zones are quite diff than yours, so I need to normalize the timeframes...thanks
/ how to best prepare garden from grass covered sod and weed seeds #33
The problem with pre-emergent herbicides is that they also prevent vegetable seeds from germinating. I guess it would be ok if you are just growing transplants.
/ how to best prepare garden from grass covered sod and weed seeds #34
Pre- emerge does NOT prevent veggies from sprouting! I spray half dose after I till and lightly incorporate it in then plant.
I have used Me-Too for all the years its been out.
It can be applied a couple weeks before you plant but dont till more than 2" deep before you plant or you mess up the herbicide layer and get seeds above it. Thats why I wait til I am ready to plant and ground is still loose from the tiller.
I fall plow deep with a moldboard plow after I subsoil 36" deep with the subsoiler then in spring till 2 times with the 72" KK tiller on the 340 tractor.
After the second till, I spray, incorporate, then plant.
Been doing this forever here in central Il.
Yes, you are correct...what I plan on doing is buying these types of seeds and germinate them in 3" plastic containers and transplant:
-3 types of squashes
-2 types of string beans
-smaller 'pickling' cucumbers
Already in 4 & 6 pack plants:
*3-4 diff types of tomatoes
*2-3 types of peppers
*jalapeno peppers
*eggplant
*onions
Seeds I will forego:
-carrots
-radishes
-lettuce
/ how to best prepare garden from grass covered sod and weed seeds #36
seems like an awful lot of unnecessary work.
My wife and I made a small garden a few years ago, we used unbroken ground covered in grass and weeds.
It was winter (in the south) so we scraped a bit of the dormant grass to begin with.
I rented a 5' tiller and tilled the area twice. My wife raked the few bits that were left.
I ran the tractor in the newly tilled fluffy dirt, and that's how I made the rows, the tires made the low flat areas, and the middle was the ridge to plant in.
When grass was cut on the weekends, my wife put fresh the clippings (grass, weeds, seeds and all) on the ridges and then eventually in the troughs for weed control. To my surprise that all worked well.
Pretty simple process really. No chemicals, etc. don't over think it.
Just till it this year and see if your family maintains care and interest, if they do and want to continue, address any issues next year.
/ how to best prepare garden from grass covered sod and weed seeds #37
I don’t understand how this works. Pre-emergent herbicides prevent seed germination of all plants, not just weeds. Is this a timing thing? Please explain.
/ how to best prepare garden from grass covered sod and weed seeds #38
You won't find a watermelon, cantaloupe or strawberry patch of any size here in Florida that isn't on plastic with a drip irrigation system, so these farmers down here haven't got the memo yet about how bad that plastic is, there is a u-pick strawberry patch about 2 miles down the road and they have been planting all their vegetables on plastic for the last 20 years, same piece of dirt year after year.
/ how to best prepare garden from grass covered sod and weed seeds #39
Have you tried fencing your garden and dropping in a half dozen chickens? I think chickens would go to town on those dudes.
/ how to best prepare garden from grass covered sod and weed seeds #40
Some people plant through plastic, but I have only used it to kill the plants on new plots. Then I pull the plastic off, plant and mulch with newspaper or straw. Once it gets wet, it isn't going anywhere. Over the years, I have invested in soaker hoses which I run through the planting so I just turn the faucet on and off. Of course, in our climate we don't have to water nearly as much as you folks in the South do, especially with mulching.
DITCH WITCH JT60 ALL TERRAIN HORIZONTAL BORING MACHINE (A60736)
DITCH WITCH JT60...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2018 FORD TRANSIT 350 4X2 CARGO VAN (A59906)
2018 FORD TRANSIT...
