Why not a small PTO rock crusher?
   / Why not a small PTO rock crusher? #11
A rock crusher isn’t a cheap piece of equipment and requires a lot of maintenance. You won’t make many tons per hour either. Just buying a load of gravel would look cheap compared to trying to DIY it.
   / Why not a small PTO rock crusher? #13
Go to alibaba.com and search for "rock crusher." 7000+ hits.
That's where I go when I'm in a whimsical mood.
   / Why not a small PTO rock crusher? #14
Are you talking soil tiller/crushers or portable/towable rock crushing plants?
Either way your crusher needs a lot of mass or it will beat itself to death in no time.
   / Why not a small PTO rock crusher? #15
I saw the Chinese one. Still motor driven and the guy had to do a ton of work to it before he could use it.
   / Why not a small PTO rock crusher? #16
It would seem that it would be a benefit of having one's tractor free to move rock while the crusher is operating, unless one has several tractors.
Impact was mentioned. Perhaps rather than PTO driven, one should get a loader with high flow hydraulics and use it hydraulic pump driven.
   / Why not a small PTO rock crusher? #18
So......I watched that Chinese rock crusher video. I guess it would be OK if you wanted to crush rock - as a hobby.
I have a mile long gravel driveway. Local contractor estimated 200 to 250 cu yds of gravel to resurface my driveway. Around 15 to 20 dump truck loads.
If I had sufficient rock to be crushed - crushed rock eight hours per day - don't think I would live long enough to "make" 200 cu yds.
How many have actually witnessed a multiple crushing/screening operation. It is a massively huge/noisy/expensive operation.
For $5000 you can get a whole lot of gravel. Of all sizes, shapes, grades, types - etc, etc.
   / Why not a small PTO rock crusher? #19
Yeah, I thought about that a lot before I bought one.
I hate rocks and I need gravel for my drive, but you're right, I will never produce enough gravel for the driveway.
   / Why not a small PTO rock crusher? #20
steve tyn don't give up just keep crushing rock a little at
a time and you will have a drive way full before you know it
willy
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2005 GMC C8500 Flatbed Service Truck (A55852)
2005 GMC C8500...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
STAR EV 36V...
Eagle Weathervane (A55853)
Eagle Weathervane...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
