Weld table, what tools are your favorite?
/ Weld table, what tools are your favorite? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
I built a weld work table this fall and loving it. Did a few project on it already and now I'm adding tools to it. What are you favorite tools and accessories do you have with ours? Do post pics.
/ Weld table, what tools are your favorite? #4
Like you, I love using the flap wheel on the grinder to smooth all the sharp edges away. I also see in the next picture that you have another grinder with the thin cutting disc. I wish I had 2 grinders so I wouldn't have to constantly switch the discs from cut to sand.
So using the .035 mig to weld thick metal, do you get good penetration/weld build up? Or do you have to make multiple passes, or lay it on extra thick with lots of swirling in one place then moving along?
/ Weld table, what tools are your favorite? #5
2? you need 3 grinders, 1 with cutting wheel, 1 with a grinder disk, and 1 with a flap disk! :)
Also, Get 3 identical ones! I have 3 different ones (one is 4" other 2 are 4.5") and they don't even use the same wrench and one needs a different shield for a cutoff wheel vs a flap wheel or grinding disk.
I am watching for my favorite of the 3 (The Milwaukee) to go on sale and I'm buying 2 more then I'll sell the other 2.
/ Weld table, what tools are your favorite? #6
I actually bought a 2'x4' rolling welding table years ago when on a promotion sale and it has been so worth the money. It has the round holes spaced evenly for jigs and clamps. I (and my knees) just like having my workpiece at a comfortable height instead of kneeling on the concrete shop floor. I bought 2 clamps that sit in the holes for clamping pieces and they work really well.
/ Weld table, what tools are your favorite? #7
I have 2 grinders with a course wheel, a fine wheel, a wire wheel, and a flap sander... and a 4 " belt sander with a 6" disc all mounted on a bench... then I also have a pair of handheld 4" disc grinders plugged in kept on a shelf under the Vise end of the workbench. A drawer filled with a variety of vice grips is handy.
/ Weld table, what tools are your favorite? #8
I find a rotary positioner to be pretty handy for making nice welds around things
Kinda of what I use, sort of. I had an old Bison 3 jaw chuck (threaded) that I made a positioner out of. I turned and threaded a dummy spindle and mounted it on a variable speed drive that I can clamp to the welding table so it rotates at whatever speed I require to weld at, which is usually MIG but I do mostly TIG anyway.
I was given a 4x6 sheet of 3/8" hot rolled plate that I fabbed up legs (on industrial casters) that is at 'sitting' height. It came with no holes, so I laid it out and used my mag drill to drill the required holes at the correct spacing and I use the cam lock toggle clamps and various blocks to jig everything I weld up. I only did half the table. The other half is not drilled. I typically weld large stuff. I'd say the table weighs about 1000 pounds but rolls effortlessly on the industrial casters. far as grinders go, I use many, both air powered, cordless and corded and many different wheels and wire brushes and the table is hard grounded which is necessary when welding with high frequency TIG. I buy my wheels and flap discs in bulk. Cheaper that way. I really like the HF 4.5" grinding wheels when on sale, I vacuum them up but then I also have a 10" corded grinder for the big jobs. The HF thin kerf cut off wheels are nice as well but I don't use a lot of them as a rule. I much prefer a plasma cutter for severance.
/ Weld table, what tools are your favorite? #10
Aluminum framing square, clamps.
In welding the 3/8, I just ran it slow and slightly down hill, pulling the puddle. The forged hook was Ved out. Seemed to weld fine.
/ Weld table, what tools are your favorite? #13
My new favorite tool is this simple MIG gun holder.... Got so tired when laying MIG gun down and reeling off a bunch of wire I finally had to make one.... Since there is no hardware/welding supply store locally that has one, yes I made it... Found magnet for $7.99 at local hardware and then a little flat stock and a bit of 3/4 inch "gas" pipe... Yes welds are just "tack's" for now but soon I might finish welding it if I find I like this creation...
/ Weld table, what tools are your favorite? #14
View attachment 846550 View attachment 846551
I really like your idea. I'm gonna make one for myself. I keep using different methods, hanging my TIG torch or MIG gun off of whatever is convenient. I hate it when the trigger on the MIG gun gets pressed and there is wire all over the floor. Your idea is great. Thanks for the pictures. BTW, I have been TIG welding for over 30 years, MIG welding for over 20 years. You'd think I'd get a clue.
Eric
/ Weld table, what tools are your favorite? #15
I have 2 of these HF magnetic Mig torch holders and I think they work good.
I leave one on top of the welder and the other one on the welding table.
KC
I like your holder idea as well. Will get one. We've got snow here which make us rather busy but I'll post photos and comments later. I have three 4.5" grinders all with different wheels in them.
/ Weld table, what tools are your favorite? #17
I have four, the additional one has a wire cup brush.
Edit: Oh, I have five, I forgot about the big Makita 9" grinder. It's a monster, gotta really have ahold of it when you pull the trigger.
/ Weld table, what tools are your favorite? #18
Cordless grinders? DeWalt 20 volt brushless and an old 18 volt, all my corded grinders either have new or spliced cords the repaired ones are definitely not OSHA approved lol.
/ Weld table, what tools are your favorite? #19
I made one just about like yours a while back.
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
2011 Porsche Panamera Sedan, (A61574)
2011 Porsche...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
