More problems on the 425 Kohler CH25
   / More problems on the 425 Kohler CH25
If…the engine isn’t running and I’m just bumping it over, would the electronic system have anything to do with stopping the physical action of the piston pushing up air out of the spark plug port? I would think at that point it’s just a mechanical action/process and if rings were good it would have to push the air up, yes? (See? I have a weird/warped way of mechanic-ing 🤪)
   / More problems on the 425 Kohler CH25 #22
The latest has been: no compression at all—zero—on both cylinders
If the pistons are moving up and down and there is truly zero measured compression then either your gauge is broken or the valves aren't closing. Or there are holes in both pistons.
Eric
   / More problems on the 425 Kohler CH25 #23
Your crank and your cam are not coordinated like they should be. Suspect your timing chain/belt/gear either skipped multiple teeth or sheared a woodruff key
The other option is you have a valve bent on both cylinders or as mentioned a hole in both pistons.
I would definitely eval your crank/cam link and maybe check for air going the wrong way when cranking i.e. out the carb instead of in.
If I had to guess I'm betting on crank/cam gear woodruff key
   / More problems on the 425 Kohler CH25 #24
A quick and dirty test to see if your valves are closing and your pistons are intact is to use a compressed air blowgun with a rubber tip for sealing on your spark plug holes when your valves are at their highest points (springs extended). If you're building pressure then everything is closing/intact and you likely have a crank/cam timing issue. If you're not building pressure it's going to be blowing out the carb or exhaust or into the crankcase all of which are easily verified and you've got a bigger problem requiring engine disassembly
Blowgun rubber tips:
   / More problems on the 425 Kohler CH25 #25
There is no shame in taking the engine to a good small engine shop for their assessment.
You know, I’m slowly starting to change my outlook on some things—especially the “I’ll eventually figure this out…” meanwhile, other things just keep popping up and my age is slowing me down. IF…it didn’t appear to be so much hassle getting all the hydraulics away from the motor, I’d probably already have it figured out. I’m wimping out more and more each year—and I ain’t liking it! 🤪
But you’re right. It would be the smartest thing to do. 😊
Thanks for this straight-ahead, more simplistic approach. That’ll be my very next move. (IF this danged cold and wind would let up! 🥴😜)
   / More problems on the 425 Kohler CH25 #28
As we get older, and more financially secure, I had to tell my wife it was OK to get the appetizer if she wanted it. ;)
   / More problems on the 425 Kohler CH25 #29
Hmm. Well looking further into the ch25 specifically looks like the mating gears on both the crank and cam are manufactured and sold as one piece integral crank/gear and cam/gear assemblies. Makes it less likely but certainly not impossible that the gears have spun on their respective shafts
Thanks very much for that! 😊
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
iDrive TDS-2010H...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
Vermeer 605 XL Round Baler (A59814)
Vermeer 605 XL...
