More problems on the 425 Kohler CH25
   / More problems on the 425 Kohler CH25 #41
Thanks for the update, and congratulations on finding a few problems. Hopefully, it won't take much to make it right.
All the best,
Peter
Geez…I’m blown away at how much crud and baked-on deposits I’m finding…later last night I was able to remove the exhaust valve from head and best I can tell it looked ok, just pretty cruddy. I THINK after cleaning it and the guide it looks like it’s settling better, but I’m not totally sure…
So, going forward from this point, what do you guys recommend? Clean up both valves, maybe relap the edge, of course new gaskets? Go ahead and do both heads while I’m at it? (and bleed those lifters too)
   / More problems on the 425 Kohler CH25 #43
Considering what could have been wrong here you're getting off easy/cheap.
If by "relapping the edge" you mean spinning the valve against the valve seat with lapping compound, I would consider that a bare minimum for repair (in addition to a head gasket). I would eval your valve guides very carefully -why did the valve stick in the first place? Varnish? Guides shifted or oblong? Why did your pushrod bend? Was it indeed your hydraulic lifter and if so why did that happen when it's designed not to?
I’m still holding out hope I’m “getting off easy/cheap”…LOL
Yes, that’s what I meant by “relapping”.
The guides—my thinking is the valve was sticking because of the buildup of crud, varnish, etc. I mean, it made a believer out of me to see how bad things can look with bad or wrong oils, lack of maintenance, etc.
The more I’ve learned about these lifters and then seeing the actual results before and after bleeding I could see how the rods would bend. (I cut off an end of an old rod and chucked it into a drill press, then tried to compress the lifter—I ended up having to use about as much pressure as my arms could do, to slowly push out/bleed the oil from inside. After a little while of doing that, they operated just fine, with finger pressure.)
Hope that helps explain a little better.
   / More problems on the 425 Kohler CH25 #45
I would consider replacing the lifters as well as they seem to be varnished internally.
Seems like this engine has seen crappy oil, prolonged oil change periods, extended operation at borderline high temps, or a combination of the above.
I don't have any personal experience with detergent oils but from the pics and what you're describing I'm wondering if running with one for the first 10 or 20 hours before changing the oil with a good synthetic might be a good idea to reduce some of the deposits/varnish. Maybe others with experience can chime in here
   / More problems on the 425 Kohler CH25 #46
There are a variety of sludge / varnish remover products out there, e.g. SeaFoam in the oil, etc. I think any of them would help, and be a prudent course of action. I have used them to clean up various engines, and they all work, at least to some degree. My advice would be use one of them, run the engine hard for ten hours or so, change the oil and filter, add some more detergent / or Tuffoil, and do some accelerated oil changes for awhile.
It isn't my money, but having owned a number of engines with hydraulic lifters, I would change the hydraulic lifters. It is tough to get them clean without disassembly, and not all versions disassemble easily. They need oil to operate, and they really should not go in and out with finger pressure. I suspect that having forced the oil out of the lifter, where it was doing its job, you now have some air inside, allowing the motion with finger pressure. I think of the concept of a hydraulic lifter as using engine oil to expand the lifter to just the right height, keeping the valve clearance at the optimal height. If they are super springy, they won't keep the height up. (They need pressure to overcome the resistance of the valve springs after all.)
I think from the damage that your engine, @Modrob, has apparently had, there was probably a loss of lubrication, probably due to fuel in the oil, and you are working through the after effects.
I think that the good news is what you have found is all readily fixable.
All the best,
Peter
   / More problems on the 425 Kohler CH25 #47
Marvel mystery oil seems to work for me?
Have an Excursion with over 100k and a little valve train noise. Used the MMO and it runs like a sewing machine now-can hardly tell the engine is running.
I put MMO in everything now-including the PT1460.
Good luck.
   / More problems on the 425 Kohler CH25 #48
I would also pull the other head and disassemble/clean the valve assemblies, lap the valves, and replace the lifters on the other cylinder as well. A sticky/intermittently closing valve on the other cylinder would explain the no compression one day then compression another day as you described
   / More problems on the 425 Kohler CH25 #50
Good luck.
I am a FIRM believer in Marvels mystery oil, been using that stuff for over 35 years. Subaru dealers use it to free up sticking lifters, I put it in my gas and oil. It is good for lifters and seals, i have seen it free up a stuck oiling ring on a caterpillar engine. It’s the real deal.
2015 Komatsu PC490LC-11 Hydraulic Excavator, S/N A42603, PIN# KMTPC251HFWA42603, Turbo Diesel (A59076)
2015 Komatsu...
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
2008 VOLVO EC210CL EXCAVATOR (A52709)
2008 VOLVO EC210CL...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2012 KENWORTH T4 SERIES BOBTAIL (A58214)
2012 KENWORTH T4...
Hook & Cable Strap (A59076)
Hook & Cable Strap...
