front end weights vs chains
/ front end weights vs chains #1
ucforme
New Hartford,NY
Kubota BX2200
Good morning, I have a Kubota BX2200 and a 3pt Frontier 54" snowblower (500 lbs.). I put approx. 200 lb of weight on front end abd it did almost nothing to help with steering or traction. Would I be better off with chains on front and back? I know the blower is a little big, but I got a hell of a deal on it. Thanks for ant input.
/ front end weights vs chains #2
Chain up the rear, that should be all you need unless you have a very steep driveway with lots of ice. I live in the snowbelt, use a rear mounted blower and chains on the rear tires. Works great for me.
/ front end weights vs chains #3
Front weight should help with steering problem
/ front end weights vs chains #4
My first 6 years back to the UP of Michigan I put a 50" Buhler rear snowblower on the back of my B7100DT. Don't know how much it weighed, but it was heavy and made the front end very light.
I put a flat steel bumper on the front and hung two 150 lb chunks of steel on the bumper to keep the front end down so I could steer. Worked great and moved a lot of snow with it.
Here's the bumper, no pictures of the weights handy.
/ front end weights vs chains #5
Yes. Chains make a huge difference.
/ front end weights vs chains #6
Back in the day - when we actually got snow here. I would chain up all four wheels on my Ford 1700 4WD. It helped the front end go straight - the V-bar chains gave superior traction - the tractor rode like a COB.
Normally - I used only the rear blade. A few times we got deep snow and I used my 3-point blower.
I had a FEL with bucket on the tractor ALL the time.
Now - we get a "splash" of snow - lots of rain - muddy spots in my mile long gravel driveway.
The R-1 tires provided adequate traction about 90% of the time. The chains provided superior traction.
If you decide on chains - get HD chains that will do some good. V-bar or the European style with studs
/ front end weights vs chains #7
Chains on front helps. So does studding all four tires.
2000 NEW HOLLAND 5554 BACK HOE (A66091)
2000 NEW HOLLAND...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
HARDEE DITCH BANK MOWER (A64278)
HARDEE DITCH BANK...
METAL GRAVITY WAGON (A64278)
METAL GRAVITY...
2015 Chevrolet Equinox SUV (A64557)
2015 Chevrolet...
3144 (A63117)
3144 (A63117)
