Smokeydog
Elite Member
Sometimes you can slab off for a 24” square or cant if not too much flare.
I've milled bigger ones than that, you get a bunch of lumber out of them!I'd be loading that onto a trailer and hauling it to the local log yard. There's no way I'd wrestle that thing around.
No doubt. You also have a better mill, equipment suitable for the task, considerably more experience, and often have younger muscle to help with the heavy lifting.I've milled bigger ones than that, you get a bunch of lumber out of them!
SR
I wasn't either... I know what you have and what I've got.BTW, I wasn't implying that I have a better mill or that I know any more than you or anyone else here,
At least you can run down to Harbor Freight and buy another, and it shouldn't be that difficult to switch over.We have cheap harbor freight mill. Worked great for it intended purposes for the last 8 years or so. Went out today to run and the small predator engine was locked up. Oh well, 1 more thing to add to my honey do list
That is indeed a smart tip about larger gravel! Although I suppose after milling just a few logs, you'll have sawdust and bark bits covering the ground everywhere anyway.A little update:
I had to flatten a spot for the saw at the mill. It has been pretty wet here, more rain tomorrow. Then a nice dry spell which will allow some gravel on this spot. My buddy gave me a great piece of advice. Use good sized gravel so you don't get little rocks stuck in the bark. I plan on using 2-3" crushed concrete that I can get for $20/ton.
Once I get gravel down I will build the PT wood base for it.
The mill is going together really well! This thing is HEAVY duty!
I hope to be milling by next weekend!
It is pretty flat. I will make it flatter with gravel and might have a bit of variation in the legs of my wood base to level it perfectly.That is indeed a smart tip about larger gravel! Although I suppose after milling just a few logs, you'll have sawdust and bark bits covering the ground everywhere anyway.
Is that area flat? Looks sloped away towards the cliff, but photos are deceiving. Any plans for a roof structure over the mill? Or is tarping the plan.
Yes sir, check!!Regarding rock and dirt caught up in the bark. Try as much as possible to never drag your logs. If you have the equipment lift them and carry them to put onto your mill.
