House Build 2023
/ House Build 2023 #321
Get a roll of blue tape and look at all your tile. It's easier to get somebody to come back and fix a grout issue, or bad touch up paint now, then after you have moved in and paid everyone their last check. Then put a piece of tape everywhere that you see an issue. Same thing with your cabinets, counters and fixtures. If you see something, put some blue tape on it. Do not rely on your memory. If you find a lot of issues, take pictures too. It's not unheard of for a guy to come back, fix a few things and remove all the tape to pretend that he fixed everything.
Open and close every door. Look at the spacing around the door and the frame. Especially at the top of the door. It's crazy how many times I've seen the opening at the top of the door be bigger on one side then the other.
Do the deadbolts work freely and is are the door seals good? It's not uncommon to install the dead bolt so it's loose because it's easy to open and close with a key, but then there are gaps around the seals that let cold wind in. Exterior doors are steady work for me.
Turn on every light switch and make sure it does something. It's crazy, but it's almost common to find switches in a house that nobody knows what they go to.
Double check your three way light switches to make sure they work from both sides. I was in a very high end, 5,000 square foot house on the lake that had a three way switch in the hall to the garage that didn't work from both ends. They just got used to it and only mentioned to it when I was all done with a project for them and was getting ready to leave. Turned out that one switch had the wires backwards and it had been that way for over a decade.
Is drainage good around the outside of the house? any standing water?
Do you have the leftover materials so you can match them in the future if you need to make a repair? Paint cans? Stain cans? Grout? colored caulking? Same with flooring materials. Be sure to have the box it came it. Most have lifetime warranties that are totally worthless. If something goes wrong and it's their fault, they will send you a replacement for free. They don't do anything else, that's up to you. So you need to know what you have on your floor so you can try to find it if you need more. I'm doing a bathroom tile floor repair later this month where the plumbers broke through the tile to get to a leaking pipe. They only have a few pieces of tile that where leftover from when the house was built two decades ago and that tile has long been discontinued. They have spent months looking for it. Since they don't have enough tile to remove all the broken pieces, I'm going to cut some in place and use the full pieces that they do have for the middle of the bathroom. I think it will work, but I have to be perfect and not make any mistakes to make it look like it was the original floor. The more materials that you have left over, the better off you will be when you need them in the future!!!!!
I also tell clients to save the boxes of their fixtures. If a faucet starts to leak in a few years, most of the big name manufacturers will overnight you a new cartridge to replace the leaking one. They just need to know the model number of the leaking faucet. Almost nobody saves this information, and 90% of the time, they end up buying a new one when they could of gotten the repair parts for free.
Keep a list after you move in of things you find that need fixing. Here in Texas, the warrantee is for one year. If it's a small thing, just write it down so you don't forget it when you call for things to be fixed.
/ House Build 2023 #322
Wow. What a great checklist!
/ House Build 2023
Neat place for a light... The middle is also a light...
/ House Build 2023
Those beams really set off the wood on you ceiling!!! Very nice.
How high up is your fan? On the box, there should be a diagram showing where the fan needs to be from the floor to be effective. Too high and you don't get any air movement.
Update on the fan. I think it moves plenty of air. We spent a couple hours in the great room talking to some friends over the weekend. I turned it on in the "reverse" direction and i could feel warm air coming down the walls and mixing at floor level. That is exactly what i was hoping for. It's not strong enough to move papers on the island but it is mixing air.
/ House Build 2023 #325
Fans are funny. I've installed them 7 feet off the ground and nobody could fee the air, other times, they move so much air it's uncomfortable. It's good to hear that you got a good one and it's working like you want it to.
/ House Build 2023
It's been raining nonstop for 2 weeks or so. The cold snap we got held up the last box of tile so we are still without a toilet in the master. But, we are starting to move stuff in today. Here is a short walk through of the mostly finished product. Ignore my heavy breathing i tell myself it's the awesome mic on this phone....
/ House Build 2023 #327
Very nice house!!!! Congratulations.
Looks like you have plenty of closets!!!!! It's funny how many houses don't have anywhere to store stuff.
What did you use for a door on your "Safe" room? I saw the cinder block walls on your video, but didn't see what the door looked like. Eventually, I want to build one in my house because we've had tornado's ten miles away.
Gun safe in the master is great!!!
Looks like you have your laundry right next to your master closet. I saw something like this in a clients house years ago and it was the smartest thing I ever saw in a house that nobody ever does. When I added on to my house, I put the laundry inside the Master Closet. It just makes so much sense to take the clothes out and hang them up in the same room.
/ House Build 2023 #329
That's a good looking door!!!! I'm looking forward to the day that I can build my room. Every time there's a tornado in the area, we have to decide what we're going to do, and how we're going to try and save the dogs. Our best option is to climb into the bathroom and hope for the best with one or two of our six dogs. When I build the safe room, we're going to put dog kennels in it so we can lock them up if things might get bad and not worry about them.
/ House Build 2023
2 Weeks in and we are loving it! So far there is nothing we feel like we really messed up on, or big things wished we would have done differently. But, I did have the bottom of a box fall out while I was carrying it and 2 bottles of nail polish exploded all over the floor and wall... I was that kind of mad where you just get totally silent... The girls noticed and took over for me cleaning, and re-painted the walls. It was fixed within an hour.
Everything is out of boxes and organized how we think is best for now. We have a bunch of crap, way more than I thought.
A few observations of note: The big shower is for sure the highlight of the day. I am surprised how dry the air is in the house compared to the mobile home and previous house. We have an alarm clock in our room that also displays relative humidity, it stays around 35%. The trailer was closer to 60% most of the time. I really like having a garage to park in again. My poor car is sun faded and clear coat coming off of it, but it sure is nice going out to no frost and not having to worry about walking through the weather. Vented gas fireplace puts out so much heat it's almost uncomfortable standing in front of it. Even with our huge great room with super high ceilings, it heats up the space noticeably within an hour or so, and just keeps getting hotter.
/ House Build 2023 #334
A big walk-in shower is a game changer for sure. You'll hate having to use a cramped shower stall or tub shower in the future now that you experienced a roomy one.
/ House Build 2023 #335
Hope the dry air doesn't cause any issues. With my wife and I, we get itchy skin from dry air, so this time of the year, we run a humidifier to add moisture to the air. I think the wood stove makes it even worse, even though we keep a pot of water on it all the time.
/ House Build 2023 #336
Don't know if you can adjust the humidity, but 50% is comfortable for me.
Having a garage/barn to park in is great.
/ House Build 2023
The weather was really nice this weekend, aside from the sporadic rain. I was able to get up before sunrise Sunday morning and sit on my front porch. I drank coffee, watched the birds, and did some reading. 3 Canadian geese and a Great Blue Herron came in to use the pond while I was out there. It was really nice.
This is part of the view from the front porch.
2022 EZ-GO ELITE...
DYNAPAC CC524HF DOUBLE DRUM ROLLER (A64279)
DYNAPAC CC524HF...
1773 (A64280)
1773 (A64280)
UNUSED RANCH HAND BRUSH GUARD (A64280)
UNUSED RANCH HAND...
HAY MASTER DOUBLE SQUARE FEEDER (A63291)
HAY MASTER DOUBLE...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
